Rumbling Sound on Passenger side
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by SteveBass, Jun 10, 2024.
  1. SteveBass
    SteveBass Junior Member
    Prius V 2012, 125K miles
    The car's developed a rumbling sound coming from what seems like the right front
    tire area.
    Some details:
    1. It occurs at all speeds.
    2. It's not a consistent rhythmic rumble (as in some part rubbing against another part).
    3. The rumble is all the same volume.
    4. It's chaotic -- in that I'll hear many short rumbles, silence for a few seconds, a single rumble, two rumbles in a row, sometimes three rubles, with no consistency.
    5. I can feel the rumbles, a sort of low vibration.
    6. It's not connected to anything on the road -- it's will happen on a smooth, newly paved asphalt road.
    My mechanic thinks it's the struts.
    I took many pictures (below). There's fluid covering the area on the inside of the right front tire as well as on a bracket below. (Sorry, I can't ID the parts; could be the strut, could be the brake.)
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,913
    4,676
    Texas Hill Country
    Struts could be bad but the leak should be small and localized to the strut. Bounce test them.
    A cv joint can splatter grease but that requires a torn boot. An easy to see diagnosis. However a bad cv joint can happen without a tear and could cause vibrations, usually far worse on turns.
    Both of the above are rare on a Prius with oem parts.
    A timing chain or pressure switch leak will dump oil everywhere on the right (passenger side). Tricker to see but common. It is would look like motor oil and not grease.
    A worn wheel bearing / hub assembly can make a humming noise and is relatively common.
    Most experienced mechanics can diagnose any of these. A trip to the dealer for a proper inspection might be worth $150 without risking changing good parts.
