Running down the battery
Discussion in 'Gen 3 Prius Main Forum' started by MaggieMay, Nov 9, 2009.
  1. MaggieMay
    MaggieMay Active Member
    534
    68
    Gloucester, MA
    In another thread about what you would add to the Prius, someone mentioned a nightlight-type gizmo that would run off the little 12v outlet. That seems so logical to me that if it's not already available it darn well should be--especially for the dark under-console space. But, would keeping that little light going contribute to running down the battery if you didn't unplug it everytime you turned off the car? Is keeping my phone charger plugged in all the time running down the battery?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    My understanding, is that the 'cigarette lighter' is disconnected from the battery when off, so you can't charge the battery when off via the lighter, nor drain it. I could be wrong, or it may only apply to Gen II.
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Jimbo is correct - Cigarette lighters are only powered in ACC mode or higher - though some have modified to do otherwise. I leave my chargers plugged in full time and have left the car sitting for a week or two w/o consequence.
  4. MaggieMay
    534
    68
    Gloucester, MA
    Okay - I always leave my charger plugged in too. Glad I'm not slllooowwwlyy draining the battery.
    Thanks!
  5. MaggieMay
    534
    68
    Gloucester, MA
  6. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Wow, $22 (and at half price) for an LED light? It says it uses a AA battery. Most LED lights using only a AA battery last for months (maybe years). Looks like the only real advantage of this one is that it rests in the lighter making it handy to get to.
    I remember in the early 80's I had a light (no batteries) that plugged into the lighter socket and it had a flexible goose neck. Pretty handy for about anything, assuming your lighter socket was in an area that gave it a good range.
  7. MaggieMay
    534
    68
    Gloucester, MA
    Hey WV! Actually I found a bunch (with Goosnecks too) I liked this one because it would be the least conspicuous down there and not in the way of the junk, um, valuables that I tend to stow under the console.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    We always called those "pimp lights". :D
    Tom
