running on battery only with no gas engine operating
Discussion in 'Toyota Prius Service Bulletins - TSBs' started by djhatton, May 13, 2011.
  1. djhatton
    djhatton New Member
    Henderson, Nevada
    :confused:2004 prius started up on battery only, ran down to the lowest level and gas engine was not operating. MPH down to 5. Stopped, shut off engine. Restarted the car. Got gasoline engine running and was able to recharge the battery while driving.
    Dealer response: Regprogrammed engine ecu per tsb eg047-04. Then they charged me $114.
  2. nerfer
    nerfer A young senior member
    2,474
    208
    28
    Chicagoland, IL USA, Earth
    That fixed the problem? I hadn't heard of this one before, hopefully you didn't damage your batteries doing that.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,185
    Nixa, MO
    That's a very old TSB (Oct. 2004). A bit surprising you hadn't had that update done at one of your routine service visits.
  4. Patrick Wong
    18,192
    6,415
    The ECU reprogramming is covered under the Federal Emission warranty of 8 years / 80K miles. Hence if your car's odometer shows a lower reading, that work should have been performed free of charge.
  5. checho 5150
    checho 5150 New Member
    Central Oregon
    our '06 wouldn't run off the battery with a full charge. it completely shut down. put gas started right up. i always wondered.
  6. bisco
    46,237
    welcome!
    that is strange, my 08 went a mile on ev after the gas ran out
    kmsbanr likes this.
Loading...
