Running on Empty.......
Discussion in 'Prius c Fuel Economy' started by Carrollights, May 18, 2012.
  1. Carrollights
    Carrollights Member
    56
    48
    WV
    I was coming home from work yesterday and I drive 62 miles each way, by the way my Prius C is at 5600 miles as of this morning, and when I left work my gas gauge started to flash so I was going to see how far I can go before I actually run out of fuel, 35 miles into my drive, I lost the gas engine and I was driving 52 miles per hour on the battery for 2.5 miles. mind you it was flat road and there was almost zero power to the tires but it kept me moving, but I got to the gas station and the car took 10.4 gallons to top it off, the manual states you can drive a few miles at 25 mph, I am going to say you can drive 4 miles @ 30
    my battery was 90% charged when I lost the gas engine when I drove the 2.5 miles I still had 25% charge left, of course I turned off the air conditioning to save power
    bwilson4web and seilerts like this.
  2. UnSurreal
    UnSurreal Junior Member
    38
    16
    Waterloo Ontario
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Some folks will get 250,000 miles on their hybrid battery, others will get 2.5 miles, once. Your choice.
    Besides ruining the HV battery, you risk several fuel system problems lean mixture due to the compressibility of air, fuel pump overheating, computer lockout due to failure to start, etc.
    While I am sure being stranded by the side of the road has it's charms, here is my very best advice
    If your mother in law is in the car, get gas at 3 pips, you would never live down leaving her in a non-air conditioned car while you went for more gas (3 times, my Prius does not recognize less than 3 gallons)
    If your wife is in the car, get gas at 2 pips, same reason, just less ridicule when you run out.
    If you are alone or riding with a friend who can keep his mouth shut, get gas at one pip
    If the last pip starts blinking, GET GAS NOW. My gen 2 Prius once ran out 7 miles after the pip started blinking. (Other times I had gone over 30 miles, it is not consistent)
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Interesting. I think 2.5 miles is probably the max range. Being at highway speed when fuel cut happens makes all the difference. Since 52 mph represents 3 times the kinetic energy, but less than 3 times the moving resistance, I seriously doubt that you could get 4 miles at 30 mph.
    This is not something to do regularly. It is hard on the fuel pump.
  5. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I think you answered my question, the real gas tank
    capacity for the Prius C is not 9.5 but over 10 gallons.
  6. rjdriver
    rjdriver Active Member
    406
    168
    Rhode Island
    That 9.5 is fiction. I put in 9.77 yesterday with out topping.
  7. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    So we can see how good is a Prius C.:) Enjoy your new toy.
  8. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    This all sounds eerily similar to the "Here, hold my beer and watch this!" crowd.
    Good luck with all that.
  9. N1XRR
    N1XRR Junior Member
    33
    Lavonia, GA
    As mentioned above, the fuel pump is a concern (and a big one considering it's probably all integrated in the tank).
    I had an '89 F150 with dual tanks for several years. While towing one of my cars one day, I forgot to switch fuel tanks and let the rear tank run dry (the fuel gauge didn't work for the rear tank). After the next fill-up, the rear pump would only put out a dribble of fuel.
    A few weeks after replacing the pump, I let a friend use it to move a bunch of stuff. He did the same thing and sure enough, another pump died.
    The 3rd one I put in was an official Ford (Motorcraft) pump. It lasted until the rear tank generated a leak from a piece of shrapnel on the highway.
    Finally, my grandfather had a Civic a few years ago. Due to an inexperienced driver running out of gas, the fuel pump went out within a few days.
    Now, I always put fuel in the car when the warning light says so. Especially on a car where a fuel pump will probably be a very costly fix.
  10. Carrollights
    Carrollights Member
    56
    48
    WV
    I don't claim to be a mechanic but.... we have hybrids and the gas engine shuts down every time we stop at a red light or coast on the highway so I'm a little confused about why having the fuel run out is any different than what the engine was designed to do? shut off and back on continuously even in the manual for the C it talks about running on battery, and how can it ruin the battery? I didn't drain it, its was at 3 bars when I got to the gas station.
    I do understand the fuel pump running dry, but mine was dry for 10 minutes and when I fueled up everything was as normal as it was the day I bought it
  11. zebelkhan
    zebelkhan Member in good standing
    165
    38
    Morgan Hill, CA
    Fuel in the tank also lubricates and cools the fuel pump. Running it dry can easily damage it.
  12. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Imagine a ballet dancer doing a complicated dance, the computer constantly balancing MG2, and the ICE to smoothly give you seamless control.* Now cut off one leg. (this is different than just doing a pirouette on one leg) The dance fails.
    You have run out of gas, but the computers are still trying to start the ICE, the fuel pump is still pumping, but no gas is flowing to cool it. Soon the computer will realize that the ICE is 'broken' and immobilize it. (you will need a tow to a dealer) Meanwhile having no other 'leg' the battery is doing tasks it would NEVER be asked to do if the ICE worked. So heat is building up in the protective case much quicker than normal. And the battery cannot protect itself like it usually does as there is no other motive force and you may be in an intersection with an 18 wheeler barreling right at you, so it keeps trying until destructive failure. (The owner wisely omits telling Toyota he destroyed the battery himself, there is no warranty in being honest)
    And you are confused by how that was different than the engine shutting off at idle. Sigh.
    *Under rare conditions, MG1 is actually a motor aiding propulsion, but let's leave out heretical mode.
  13. guity
    guity Junior Member
    32
    CA
    What kind of lousy computer programmer writes a program that keeps the fuel pump working even after it has been determined that there is no more gas?
  14. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    All that the computer knows is that the ICE failed to start once. When it fails to start 10 times, then it quits trying to use the ICE and you have to tow it to a dealer to try the ICE again.
    "You are such a lousy programmer, you could not program a VCR to blink 12:00" easily the best insult I ever heard, I swear it was not about or by me.
  15. guity
    guity Junior Member
    32
    CA
    So there are computers all over the car calculating every aspect of fuel consumption including tank fullness and miles per gallon, but the computer controlling the fuel pump has no access to any of this information?
  16. N1XRR
    N1XRR Junior Member
    33
    Lavonia, GA
    If the same programmer made the engine shut off completely where there was still 1/2 gallon in the tank, but the sensor couldn't detect that you could make the same argument.
    The car gives PLENTY of warning before running out of fuel (noises and flashing indicators), the driver chooses to ignore it.
    I am a developer by trade and we have a saying: "There's only so much stupid you can program around"
  17. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    You are making the assumption that some computer controls the fuel pump, it may well be on any time the car is ready. If it was turned off and the computer wanted to start the ICE, there would be a delay while pressure builds. By running it all the time, the ICE can start more gracefully.
  18. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    That goes right along with " 'Idiot proof' is impossible, idiot resistant is the best you can hope to accomplish."
  19. guity
    guity Junior Member
    32
    CA
    So you think it is too much time spent getting around "stupid" if you set up some code that would alert the driver and refuse to activate the fuel pump until some kind of override was detected, or until gas was detected? You weren't a developer for MS-DOS by any chance, were you?
  20. guity
    guity Junior Member
    32
    CA
    I guess there would be some weighing and deciding between the value of running the pump all the time so that the ICE can start gracefully, as opposed to not running it all the time to prevent the occasional fuel pump damage from lack of gas. Perhaps consistent graceful starts on all vehicles would outweigh saving the rare, mistreated fuel pump.
    Still, one would think that eventually a design would come along that both provides consistently graceful starts AND protects fuel pumps from being damaged by empty gax tanks...
