Running out of both gas and electric
Discussion in 'Prime Fuel Economy & EV Range' started by Marine Ray, Jul 26, 2021.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    Intriguing recent 16 min video of PP owner deliberately running out of gas and electric. Pics will follow of his summation. Last pic is how much gas he put in from empty.
  2. Marine Ray
    1,139
    947
    Sparks, NV
  3. Marine Ray
    1,139
    947
    Sparks, NV
  4. Marine Ray
    1,139
    947
    Sparks, NV
  5. Marine Ray
    1,139
    947
    Sparks, NV
  6. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    I wonder if it still has the 'need to add at least 3 gallons' that the older generations of Prius had if they ran out of gas.
    That's important if you're stuck on the side of the road and have to refill from a can carried from a gas station.
    [not that I plan on trying that, I usually fill up before the last 2 divisions on the gauge disappear]
  7. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
  8. fuzzy1
    10,463
    I seem to remember that on the older generations, absent a sufficiently large refill, one could disconnect the 12V battery for a few minutes so the ECUs could lose their memory on this, allowing them to retry to start.
  9. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    No, the Gen 4 has a different (rigid) fuel tank, unlike the flexible bladder in Gen 2, that does not require a minimum fuel add to trigger the new reading.
  10. mikel1
    mikel1 New Member
    Queensbury, NY
    2018 Prius Prime
    What was the monitor app showing on the right side of your video?
