Running out of gas
Discussion in 'Gen 2 Prius Main Forum' started by Elizabeth shoffner, Aug 28, 2017.
  1. Elizabeth shoffner
    Elizabeth shoffner Junior Member
    Roseville ca
    Ran car out of gas. Towed home and filled gas tank. Car wouldn't start so disconnected battery. Would start then run rough and die. Husband disconnected battery again. Is idling fine and will drive up and down street a couple times then start running rough and die. Any ideas on what to check next? Could it be my fuel pump? Friend has a reader that gave p3193.
    49,482
    if it's running fine, there's nothing to check.
  3. Just.Drive.It.
    Just.Drive.It. New Member
    27
    25
    Here, There, Everywhere. Driving my Prius!
    I'm surprised 10 guys haven't jumped in here, and asked: why did you let your tank get so low! .:LOL: I top off my tank every other week, that way I am always good to go for whatever may come up. I don't play those mpg games.
    I just drive it.
    49,482
    just drive it, until it runs out of gas.:p
    Paranormal Rob likes this.
  5. Mendel Leisk
    38,723
    Miles per Tank games are distinct from Miles per Gallon games.
  6. bisco
    49,482
    and reindeer games.
  7. Just.Drive.It.
    27
    25
    Miles per gallon, miles per tank, I really don't care about either one. I'd rather play checkers. Or scrabble. Or monopoly.
    Just Fuel 'em up!
    #7 Just.Drive.It., Aug 28, 2017
  8. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    P3193 just tells you you ran out of gas. There may be other codes your friend's reader is not capable of reading. Disconnecting the 12 V battery will have cleared this code.
    Are there still lights on? If so, there are other codes to read, so you need a more capable code reader to read them. The Prius has 11 or more ECUs that can set codes and you need a scanner that can read all of the ECUs.
  9. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    I have two guesses:
    Perhaps there's air in your fuel lines and it will take a few miles to push it all out.
    OR ... are you sure there wasn't any water in your gas can and that the gas was fresh? If that's the case, it needs some fresh gas. The decision is whether to just add 3-4 gallons to dilute it a little but get it out of there asap or fill it up and dilute it as much as possible.
  10. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Or just some "sitting" time.
    And you indicated that you FILLED the tank at home.
    How did you do that exactly ?
    Most people don't have that much spare gas just sitting around.
  11. jerrymildred
    11,511
    14,113
    Tampa, FL
    It did say that in the OP. I was kind of assuming it was shorthand for put some gas in the tank, but I guess we'll wait and see if I assumed wrong. If they are on a farm, they may have filled at home.
    fuzzy1 and bisco like this.
  12. bisco
    49,482
    is it that unusual to have a 5 gallon jug at home? i do.:oops:
    jerrymildred likes this.
  13. jerrymildred
    11,511
    14,113
    Tampa, FL
    I'd think that anyone who mows their own yard rather than pay someone to do it and then pay for a gym membership would have a gas can at home. Except me. My mower is electric because I have wonderfully small yard. ;)
  14. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Then what happens after that?
  15. bisco
    49,482
    wow, i thought i read the o/p clearly. missed the ruining rough the second time after the running fine.:whistle:
  16. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Is yours for gasoline or moonshine? :eek:
  17. Sam Spade
    2,036
    1,023
    2017 Prius c
    Are you really asking "Am I unusual ?"
    Only one answer for that. :ROFLMAO:
    And 5 gallons won't "fill it up".
  18. Scott56
    Scott56 Junior Member
    40
    27
    Alabama
    Any car that runs out of gas and when trying to start it on an empty tank, it sucks air into the fuel pumps and fries the barrings which are normally lubricated by the gas. That would be my guess.
  19. fuzzy1
    10,167
    How well does your guess line up with the actual first hand experience of members here on this forum?
    Note that one member here intentionally ran his cars out of gas more than 50 times, for various engineering curiosity tests.
    Prodigyplace likes this.
  20. Paranormal Rob
    Paranormal Rob Active Member
    244
    107
    RDU NC
    2013 Prius v wagon
    I agree. Just an air pocket like any other car
