Running tire inflator directly off the 12V
Discussion in 'Gen 3 Prius Main Forum' started by tsair, May 11, 2012.
  1. tsair
    tsair Junior Member
    29
    Sunnyvale, CA
    Hey all,
    Had a technical question. I have a tire inflator that runs directly off a 12V car battery (it uses alligator clips to connect directly to the terminals). It draws more than what most cigarette adapters can supply, which is why you have to hook it up directly to a car battery.
    What would be the proper way to use this on a Prius? Hook it up directly to the small 12V battery terminals, and then turn the car on to READY? And then start the tire inflator?
    Thanks,
    Ray
  2. El Dobro
    El Dobro A Member
    7,075
    3,258
    That's what I would do, or at the jumping points under the hood.
  3. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Jump point under the hood would be the best/easiest. I wouldn't put the car in "ready" though. The pump could generate spikes on the 12V system. As long as you don't run it for more than 30 min. it shouldn't drain the battery much.
  4. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    If you attach it directly to the car battery, you have voltage. No need to start the car unless you'll draw so much power that you think you'll deplete the battery, which a tire inflator isn't going to do unless you're inflating a whole lot of tires.
    Of the inflator's designed to connect straight to a car battery, it should have a fuse.
  5. Myself248
    Myself248 Junior Member
    29
    Royal Oak, MI
    I just blew my lighter socket fuse doing this. My little compressor draws a ~30A surge for ~1S on startup, then 18A while running. Hasn't been a problem for any other car, where the sockets are usually fused at 20A, but in the Prius they're fused at 15. Oops. And they're those miserable low-profile fuses which are just starting to trickle into stores.
    So. "Powerpole accessory connector straight to the battery" has been on my car ToDo list for a few weeks, guess it gets bumped up to high priority. One in the rear, one in the front? Le sigh. Got some nice Airpax DC breakers for the project, though, so I won't have to replace anything next time stupidity happens.
  6. Rebound
    3,972
    2,626
    Portland, OR
    You don't need to connect physically to the battery. There's a connector block under the hood, near the fuse box, which has a direct 12V from the battery. This is easier and safer (no chance of a spark igniting hydrogen gas).
  7. fuzzy1
    10,335
    At 18 amps, that product is abusing the socket, which was not originally designed for such currents.
  8. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Following basic circuit safety rules, running any circuit at 80% means that it shouldn't consume more than 16A if it's a known 20A circuit requirement.
  9. samdaman
    samdaman Junior Member
    75
    Eastern PA
    Rule 1: start the pump before connecting the pump to the tire.
    The back-pressure from even a partially inflated tire increases the pump starting current by a huge amount.
    **mod note - merged and fixed quotes**
    HTMLSpinnr likes this.
