Running While Traction Battery is Off
Discussion in 'Prime Technical Discussion' started by Ricklll, Dec 30, 2024.
  1. Ricklll
    Ricklll Junior Member
    Sacramento
    2020 Prius Prime
    Met a deer friend that totaled my 2020 Prime. 12v battery broke. Want to replace it, but fear voltage from traction battery. Can I run on gas if traction battery is turned off?
    51,011
    unfortunately, no. the traction battery spins up the engine. if the 12v is the only thing that broke, you don't have to fear the traction battery voltage.
  3. Prodigyplace
    12,390
    11,675
    Central Virginia
    Are you sure the 12V battery broke? If the car detected a collision, it disabled the Hybrid system.
    That happened on my 2017 prius that was T-boned by a 4Runner. The tow operator needed to use a special sequence to get the car out of Park since the parking pawl normally requires the car to be in Ready node.
  4. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    The only way to turn-off the traction battery is to pull the safety disconnect, but as @bisco stated that is what's used to start the gas engine. Why don't you just replace the 12vdc battery? It's isolated from the traction battery, when the car isn't in 'ready mode'. The 12vdc battery closes two large relays to engage it - then the car goes into 'ready mode'.
    Hope this helps....
  5. Prodigyplace
    12,390
    11,675
    Central Virginia
    The OP strongly implied a collision. Are they sure the 12V battery is the issue? If the car detects a collision it will disable the Hybrid system, disconnecting the traction battery.
  6. BiomedO1
    2,725
    1,455
    SacTown, Ca
    I see what your saying, but he needs to check his systems first! Getting 12vdc to the car is the first step.......If the traction battery interrupt did trip or the main 12vdc fuse - it should be readily apparent, otherwise everything else should light up - including trouble codes.........
    Prodigyplace likes this.
  7. Ricklll
    Sacramento
    2020 Prius Prime
    Thanks for the info. The car was totaled by the insurance co. Not sure how deep the injury. The reason why I think the 12v battery is the problem, I turned the engine off when hit. I turned car on and moved to safety. An hour later I drove the car onto the tow truck. Two hours later at home could not start car. What happened in those last hours when the car died? I assume the 12v battery being damaged went dead.
    The damage to the car is primarily the driver side front fender and hood. The headlights were damaged. Driver door cannot open. Passenger side experienced some slight push back. Wires under hood appear to be in good condition, but there is some broken lights and engine cover broke. So, if I cannot start car to see what is damaged, I will have to turn off the traction battery to be safe. Am also concerned that after turning off TB and replacing the 12v, then turning the TB, I could cause damage to the system if there is a short somewhere.
    #7 Ricklll, Dec 31, 2024
  8. Prodigyplace
    12,390
    11,675
    Central Virginia
    My car was damaged mainly in the front passenger door.All 3 side curtain airbags deployed. Out of habit, I put the car in Park & turned it off. After that, it turned on with a Hybrid error & could not be placed in Neutral. Apparently, holding down the break while holding the shifter in Neutral eventually places the car in Neutral so it can be towed.
  9. bisco
    51,011
    are you buying it back from the insurance company? tbh, it sounds like you are in over your head.
  10. Prodigyplace
    12,390
    11,675
    Central Virginia
    Before my Prius was declared totalled, someone told be the body shop would need to work on it and a dealer would need to safety inspect before enabling the Hybrid system, At that time I was just researching my options.
  11. bisco
    51,011
    it's not somethng to take lightly, especially for the inexperienced
    BiomedO1 and Prodigyplace like this.
  12. Prodigyplace
    12,390
    11,675
    Central Virginia
    To add insult to injury, now when you buy a new Toyota (I paid cash) if you opt out o Toyota US marketing they just change the language to say it is a transactional email because you own a Toyota.
    Their Unsubscribe link sis only for marketing and you cannot opt out of the others even though they have marketing content. I ended up putting them in the SPAM folder & hope I do not miss any important recall information.
  13. Ricklll
    Sacramento
    2020 Prius Prime
    Again, thanks for the response. I had the car towed with a front wheel dolly. Thanks Prodigyplace for the info on neutral. In the past I wanted the engine to come on to get the heat on, but did not know how.
    No airbag went off.
  14. Prodigyplace
    12,390
    11,675
    Central Virginia
    I looked in my new Camry manual to see if I missed that trick. Although they have a section with towing precautions, I do not see this trick mentioned anywhere. If I had known that when I got pushed into an oncoming traffic lane, I could have pushed the car onto the shoulder, out of the active roadway. Instead, we had people on both sides of the curved road controlling traffic. :(
    @Tideland Prius if you are still maintaining a KB thread, this undocumented trick would be a good addition for others,
    #14 Prodigyplace, Jan 1, 2025
  15. BiomedO1
    2,725
    1,455
    SacTown, Ca
    That looks like an easy fix, but I'm pretty handy. Check your strut tower and front wheel alignment. If you don't know what I'm talking about; your probably shouldn't try to repair it yourself. IMHO, most of that damage is due to the soft, pedestrian friendly front end - doesn't look like any frame damage occurred.
    The tow company may have pulled the traction battery disconnection, and/or main relay/fuses. That's pretty much company policy for any electric/hybrid cars stored on their lot - liability/insurance issue. Check your glove box and trunk area for an orange plug.
    If you have a short somewhere, the damage would've already been done in the minutes after the crash - electricity moves pretty fast!!
    Hope this helps.....
    #15 BiomedO1, Jan 1, 2025
  16. Prodigyplace
    12,390
    11,675
    Central Virginia
    He already got it to move out of Park by using the secret procedure. Modern Toyota hybrids disable the hybrid system upon sensing a collision. No need to pull the high voltage plug any more.
  17. BiomedO1
    2,725
    1,455
    SacTown, Ca
    I doubt the traction battery disconnect was tripped. Most likely the 12vdc battery was drained due to all the damaged electrical components. He wouldn't be able restart the car and drive it to the side of the road or onto the tow truck, if it was tripped.
    This is the reason the policy exists in tow yards, there's no guarantee the primary breaker will trip - but pulling the safety disconnect will ensure the car doesn't get energized.
    There was multiple incidents where a wrecked hybrid/EV sat in a storage yard for days before igniting the battery pack.
  18. Ricklll
    Sacramento
    2020 Prius Prime
    Biomed said "If the traction battery interrupt did trip or the main 12vdc fuse - it should be readily apparent, otherwise everything else should light up - including trouble codes........."
    When I replace 12v, then the system will throw codes if there are serious problems?
    The driver's side rail has very slight damage that I can see and the apron on driver's side is damaged. Slight damage on passenger side. The plastic cover over engine is cracked. unplugged the light harness. Some damage, but much looks good. Wires are not damaged (that I can see so far). Will begin deconstructing this week. Is it cheaper to buy a wrecked plugin or are parts not that expensive?
    Are all 4th gen plugin's parts interchangeable?
  19. Paul Gregory
    Paul Gregory Senior Member
    1,365
    356
    Alberta
    2024 Prius Prime
    XSE
    Your fears are unfounded. The 12V battery is not connected to the hybrid battery.
  20. Ricklll
    Sacramento
    2020 Prius Prime
    My concern is with the voltage from the traction battery when turning on the car. There could be a short somewhere.
