Rural Carriers
Discussion in 'Prius c Main Forum' started by Speedy MamaJ, Jan 29, 2013.
  1. Speedy MamaJ
    Speedy MamaJ Junior Member
    Are there any rural carriers that are using the Prius? How durable are they?
  2. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Lots of cab companies use them.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  4. Speedy MamaJ
    Thanks for the links! BTW - what is the flying buttress? lol
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The huge dash thing that flies down like a bridge.
  6. Speedy MamaJ
    Ok another question. I am wanting to run gas and brake pedals to passenger side on a 09 model. Do they make a schematic of some sort where I can tell if there is anything under dash to prevent me from doing this?
  7. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Gen 2 like yours
    Gen 3 which is hard to drive from right
    I know the gas should be easy, not as sure about the brake.
  8. jdchappie
    jdchappie JD on RR2
    78
    Southeast Kansas
    I'm still in my 2007, 185,000 miles, original 12v battery, original traction battery, inverter pump died in Febuary,fixed by recall.
    My sub got his own route last August. Bought a 2012 Prius. He found and installed a cable operated brake and gas kit from Canada.
    Driving Instructor Supply Source for a Dual Control
    He mounted the right side pedals on plywood covered with carpet. Didn't want to drill through floor.
    Might work in a Prius v. Jerry
  9. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    I hated that buttress with the joystick shifter. That is why I got a C.
