Rust on bottom driver door on 16 mo. old Prius
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Dan Y, Dec 12, 2022.
  1. Dan Y
    Dan Y Junior Member
    57
    Brooklyn, NY
    2022 Prius
    LE AWD-e
    Ours is technically a 2022 model but we have this car since mid-August 2021 so it's about 16 mos. old. My wife mostly drives it commuting to work. This weekend I opened it and corner hit dirt of high tree well and when I went to wipe it off I noticed rust on bottom of door near outer corner. We live in New York City and street park at home in south Brooklyn so you periodically open the door and might scrape it on a curb, also they use crazy amounts of road salt (arguably too much put down when it's not even needed). But I was definitely surprised. This wouldn't be under warranty some how, would it? Also what advice can people give on DIY home repairs or non-DIY for this? Thanks!
    I did find this possible series of DIY things I could do: https://itstillruns.com/fix-rust-bottom-car-door-6016708.html
    52,750
    i think the warranty is 12 months, but check with the dealer. i don't think it would cover road rash anyway.
    best to sand it downuntil it is gone, prime it and paint. spring time is fine.
    non diy would be an auto body shop.
    you might want to report your post and ask that it be moved to gen4. gen 5 is not available until next year.
  3. Leadfoot J. McCoalroller
    8,261
    7,763
    Pennsylvania
    2018 Prius c
    I don't know about warranty coverage at 16 months, but dealing with door scrapes on curbs is a fact of life, it will keep happening past any warranty. The salt just makes it worse.
    You can diy some repairs- essentially you want to clean it, remove existing rust and replace paint to seal it. Plenty of youtubes and reddit threads with all the gory details so I don't have to type them.
    Some people put plastic or vinyl beading on there to reduce scrapes, but that's a double-edged sword: Now it scrapes even lower because of the thickness of the vinyl, and that beading will hold rain and other moisture right there, which can make rust problems worse.
    That's not to say it is a bad idea, you just have to decide which problem you want to work to stay caught up with.
    fotomoto likes this.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Door frame most likely encountered a curb or similar obstruction upon opening breaking thru the paint=corrosion=wear&tear=no warranty.
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    I had to wonder who has a 16 months old Gen5?
    LOL
    #5 Salamander_King, Dec 12, 2022
  6. Mendel Leisk
    42,237
    Consolation: bottom edges like that are the easiest places to repair seamlessly, paint just flows to where it's needed, and cures without looking like touch up.
    Abrasive glass fiber "pens" are good for clean up, down to bare metal, and cleans out the pits/grooves. Then spritz a little spray can primer into its lid, apply it with a small water colour brush, and when it's cured top coat with a Toyota colour-matched touch-up pen or brush.
    If the colour-matched pen, with colour coat at one end and clear coat at the other, maybe forgo the clear coat. Or at least test somewhere first: I found the clear tended to lift the previous coat.
  7. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    Toyota offers 12 years warranty for no rust in my country, I would certainly contact your local dealer and find out your terms of warranty.
  8. Salamander_King
    11,024
    8,977
    New England
    I am guessing you don't have road salt in your country? Around where I live, no car will last longer than a few years without rust developping on the unprotected surface. The painted body parts usually fare well, but in my experience, no car lasts longer than 10 years without developing major rust-related issues, usually underbody parts, but can be anywhere on the vehicle.
  9. fotomoto
    5,639
    3,815
    So. Texas
    The rust warranty is for rusting from the inside out. Road salt, natural conditions (living near salt water), etc is rusting from the outside in.
    Example: Certain Pacifica owners are having hood rust issues that start in the same area due to a manufacturing issue during the application process not from road chips (wear & tear). Those are being covered.
    JoeBlack and Salamander_King like this.
  10. Dan Y
    Dan Y Junior Member
    57
    Brooklyn, NY
    2022 Prius
    LE AWD-e
    Thanks everyone for all your helpful advice. Sorry about posting in wrong place, that's hilarious I forgot there's a new generation out now, when I got car and first came on here obviously it was the latest gen and I had forgotten what # that was then vs. now. Can a moderator move this to Gen 4 and not lose replies?
    Salamander_King likes this.
  11. Mendel Leisk
    42,237
    Looks like it's done. For next time: click the "report" button on the first post, note that you've posted in wrong forum.
  12. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    The Touch Up paint you get from the dealer have that fiberglsss included. Very carefully, "scrap" the rust, the use the touch up paint to touch up the missing pant. Wait a couple of minutes, add a second coat, wait a couple of minutes add the clear.
  13. Mendel Leisk
    42,237
    Not ours, purchased from Canadian dealership, but I have some "Dupli-Color Scratch Fix All In One" aftermarket that have that. I find them to be miracle workers on rim curb-rash (have 17" OEM Touring rims), much more seamless than sand paper or filing: the individual fibres ride up/down into crevises in the damage, and abrade the edges very smoothly.
  14. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Check your Maintenance and Warranty guide, pages 14 & 15, for the warranty question.
  15. Dan Y
    Dan Y Junior Member
    57
    Brooklyn, NY
    2022 Prius
    LE AWD-e
    So can I just do it all with the "Dupli-Color Scratch Fix All In One" in the right color? Otherwise can you list what you recomend using?
    Thanks so much!
  16. Mendel Leisk
    42,237
    Yeah that would do. Or just get a fiberglas brush pen without paint, and the touch up paint through dealership. Paint code can be found on driver's door decal.
    Dan Y and Doug McC like this.
  17. Dan Y
    Dan Y Junior Member
    57
    Brooklyn, NY
    2022 Prius
    LE AWD-e
    Thank you so much for your helpful response and apologies on my very delayed response. In your first message you mentioned primer, is that not needed for this or should I also get that and if so any advice on procuring that?
    So just to summarize, one needs something to scrape off rust, the correct paint color, clear coat, and maybe primer too?
    Totally separate question, do you or others know if there is a way to reliably set this site to contact me by email when I get a new message?
    Thanks again Mendel!
  18. Mendel Leisk
    42,237
    With door bottom edge scrape I’ve skipped primer, just clean it out good with abrasive brush, then wipe with isopropyl alcohol on cloth, then a couple of coats with touch up pen or brush. Follow up with wax, say a week later.
    it’s very easy to do a seamless job at that lower edge; gravity flows the paint around bottom edge.
    Dan Y likes this.
