rusted coolant heater pipe to the catalytic converter
Discussion in 'Prime Main Forum (2017-2022)' started by cossie1600, Apr 1, 2025.
  1. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    My 2018 Prius Prime is suffering from the rusted coolant heater pipe problem. The parts appear to be on backordered! The car doesn't just not have heat, it is also at risk of overheating. They push the original estimate from March into June and I have been waiting since early Feb. Has anyone seen this issue? I am very close in just trading the car in and let someone else deal with the problem
  2. BiomedO1
    BiomedO1 Senior Member
    2,821
    1,499
    SacTown, Ca
    You can temporary loop-out the effected heat exchanger section; but it shouldn't effect your heater - unless you've lost all your coolant. Install the by-pass and refill/burp the cooling system. If this is done properly, everything should operate normally; except for some extended run times - engine will take slightly longer to warm up.
    Hope this helps.....
    Brian1954 likes this.
