Rusty lug nuts deteriorating undercoat?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by TC400, Jun 10, 2016.
  1. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    My c is showing signs of rusting lug nuts and undercoating wearing away in the rear wheel wells. Would these be covered under my Toyota Bumper to Bumper EXTENDED warranty? I emailed the service manager at my local dealer but I haven't heard back yet.
  2. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Those look like cosmetic issues to me, which I strongly doubt would be covered by the warranty.
  3. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    The lug nuts appear to be rusting from impact damage as a result of using a generic socket to remove said nuts.
    IMO...no.
    (Do a net search and you'll find specific wheel sockets that are typically lined plus outside coated with plastic to prevent scratches/ damage).
    Wheel well...can't tell.
    Is that an OEM finish or dealer installed under coat?
    Why is it cracking?
    Road impacts, product shrinking from age/ drying, body flex?
    IMO...no.
    Dealer may reapply coating no charge as good will, yet simple enough for you to do if so inclined.
    Have fun....these are easy DIY projects.
  4. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    The undercoat tustve been put there form the factory. If the dealer put it out which is doubtful then they did it without my permission. I bought the car new so I'm aware of everything that has been done to it.
  5. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    I doubt either issue will be covered by any warranty.
    For the wheel well; OEM wheels and tires? Hit any potholes really hard to allow the tire to brush against the undercoating?
    For the lug nuts, I believe rust warranty is body only and then only if a hole is rusted thru the metal.
  6. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Yes the rims are OEM and it had OEM tires on it for most of its 37k. Now it has Ecopias on it.
