S modes and 12V battery charging question
Discussion in 'Gen 2 Prius Technical Discussion' started by FirstFlight, May 17, 2012.
  1. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Two questions.
    I read somewhere that in the Gen 2 you need to come to a stop in order to get into S3. Is this true? If so, could you hypothetically leave your driveway and never stop and 400 miles later be in S3?
    Regarding the 12V battery, the voltage is always 13.2 when I'm driving around. When I'm in park or neutral, the voltage goes straight to 13.8. Is this normal?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    1. Correct. You need to stop at some point, once the conditions are correct.
    2. The 12V bus is held somewhere around 13.8V during normal operation. 13.2 sounds a tad low, but it's probably an artifact of how you measure the bus voltage.
    How are you measuring that voltage?
    Tom
  3. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I used the display to check it. I could measure it with my meter but I guess I just thought that the MFD would be better since that's what the computer was seeing.
    I don't understand why it's a constant 13.2 in drive modes and 13.8 in park or neutral.
  4. qbee42
    18,058
    3,074
    Northern Michigan
    Current flow is causing a voltage drop between the battery and the MFD. Whatever is drawing the current eases off when in park or neutral.
    Tom
  5. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Ok, so it should be 13.8 at all times? If true, seems like the battery isn't the issue but the additional current load is the real problem.
  6. usnavystgc
    3,159
    989
    Tucson, AZ
    Just some clarification on the S mode question.
    You actually do not have to stop to get into S3. S3 is broken down into two submodes S3a and S3b. S4 (full hybrid mode) is actually the mode you have to stop (or slow down below 7mph) for about 7-10 seconds (also known as an idle check). When your ice is warmed up above 160 deg F (I think its 166) the conditions are right for transition to S4 but you must execute an idle check to get into S4. You are correct that if you never stop for 7-10 seconds after the ICE warms up, you will never transition to S4 but, S3b is almost as efficient as S4.
    This thread may help explain it better than me. http://priuschat.com/forums/knowled...12919-five-stages-prius-hybrid-operation.html
  7. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
  8. uart
    uart Senior Member
    4,215
    1,200
    Australia
    As per the link koolingit gave above, it's normal under some conditions.
    It should be higher (around 13.8 to 13.9) when you first start the car, but may drop by about 0.5 volts after driving for a while.
    It seems to be some kind of attempt at a two stage charger and it may only be enabled if the temperature is over some minimum threshold.
    It also seems to be disabled when you are in either "N" or "P" or when you have any cooling function (even just the fan) in operation.
  9. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    The lower charging voltage of the 12V circuit may be due to the much lower drain on the 12V battery by starting the car. The only thing the 12V battery is doing is starting up the computers and powering the main relay connecting the traction battery to the system. That doesn't take much juice.
    Perhaps throwing 14.5V at it is a bit excessive due to the very low load on the 12V battery.
    I just got a BT OBDII scanner and Torque on my Android phone, so I put a gauge up for my 12V aux battery, since it's 3 years old now and could need replacing in the next couple years. I noticed 13.8V-14.0V on the circuit in normal operation of the vehicle.
