S/O is in WY, got this warning icon
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by seeh2o, Oct 13, 2015.
  1. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    I know it means check engine, but does anyone have an idea what it's about? He has a 2009, not a lot of miles on it. Could it be that coolant pump issue from way back?
  2. vskid3
    vskid3 Active Member
    773
    228
    Check engine light is just about impossible to diagnose without reading the codes or noticing strange behavior. It can mean anything from a loose gas cap to your worst nightmare.
    As for coolant issue, if you mean the inverter coolant pump, you can check the reservoir for turbulence (skinny one with pink fluid in the middle of the engine bay). Remove the cap, turn on the car, and see if there are ripples.
    seeh2o likes this.
  3. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    Thank you, I'll pass it along to him.
  4. Mendel Leisk
    40,584
    Does your title mean:
    Significant other (spouse) is in Wyoming?
    Just grumbling.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Usually means the engine is very low on oil. No matter what when a Prius throws a DTC it's not kidding. Since its not a hybrid code
    any auto parts store can decode it with there OBDII reader.
    seeh2o likes this.
  6. Mendel Leisk
    40,584
    Per Ed, has the oil level been checked?
  7. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    Yes, the oil was fine, it turned out to be several things, I'll report back when I have a clearer understanding of it.
    Mendel, S/O does mean significant other in this case and he was in Wyoming visiting family.when the icon came up, just before he was supposed to drive home, naturally. Not spouse, but we're too old to go by boyfriend/girlfriend and have been together for 137 years, so S/O makes the most sense. Why the grumbling?
  8. Mendel Leisk
    40,584
    Touche. :)
    seeh2o likes this.
  9. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    He has no clear understanding of what the issue was, but it wasn't low oil and wasn't coolant.
  10. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    I am just brainstorming but sometimes it's a gaso cap issue if I am thinking the correct vehicle I own..and sometimes it resets itself.
