Safe to run air compressor that connects to the battery?
Discussion in 'Gen 4 Prius Technical Discussion' started by big4570, Oct 8, 2021.
  1. big4570
    big4570 New Member
    2022 Prius
    Technology AWD-e
    I have a VIAIR 88P air compressor I used to use with my jeep wrangler. I was wondering if its safe to run off the Prius 12v battery. It connects directly to the battery using the positive and negative terminals and seems to draw a fair amount of amps.
    Will running this off my battery cause any issues and is the battery big enough to support the draw from the compressor? I always leave my vehicle running when I'm using it if that matters.
  2. MPGboss
    MPGboss Member
    Los Angeles
    2021 Prius
    yes no problem.
  3. ChapmanF
    18,224
    It does matter, and as long as you do, you'll be fine.
