Safe to use JACK this way?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Stevewoods, Jun 10, 2014.
  1. Stevewoods
    Stevewoods Senior Member
    655
    1,069
    Seattle, WA
    Longtime lurker (although I posted a couple of times when I got the car back in '08) and I forgot my old sign-in.
    Anyway...I basically only change my oil and filters.
    When I change motor oil, I use the prius scissors jack to slightly lift the car enough to get the drain pan under the car and to turn the Fumoto valve that I installed to replace the drain plug.
    The wheels never leave the ground, although, of course the chassis/frame, whatever you want to call it, rises up a few inches.
    Did this this past weekend with father-in-law "supervising" and he called me about how unsafe my practice is.
    I have done this for at least 20 years with a few different cars and never had an issue. But, I am willing to learn/change. Is this really that unsafe, in the opinion of the group?
    Again, the wheels never leave the ground, I just push it up a few inches.
  2. JC91006
    16,672
    8,518
    Yes dangerous, you've done it many times but it just takes 1 earthquake to get you stuck under the car.
    If it's going only a few inches, just use a couple 2x6 blocks of wood, giving you almost 4 inches
    SM-N900P ?
  3. Mendel Leisk
    40,574
    Yeah get a floor jack and a pair of safety stands. Or ramps.
    Your current setup is basically crawling into a loaded rat trap.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    If you are under the car, you want it supported by more than a temp jack.
  5. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    +1, your FIL is right, you are wrong. ;) :D
    SCH-I535
  6. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    Use some ramps like these:
    Edit: I was trying to post a link to Rhino Ramps here but after many tries gave up.
    It will not only be safer, but much easier as well.
  7. bisco
    51,141
    if you are thicker than the space between the car and the ground before jacking it up? don't do it!
    Mendel Leisk and SageBrush like this.
  8. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I just drive one front tire up onto the sidewalk curb. That gives me enough room underneath for oil changes. Might be enough room for your drain valve as well.
  9. SageBrush
    11,627
    2,533
    Southwest Colorado
    I'm almost afraid to ask ... ;)
    How do you rotate tyres ?
  10. Mendel Leisk
    40,574
    I keep thing about your assertion "the wheels never leave the ground". Here's the thing:
    You can't fit under the car without raising it slightly. So at rest the car would be an inch or two into your rib cage. Now you've raised it with the scissor jack enough that the tire's still just touching down. You're kidding yourself thinking that equals you're safe. If and when the car falls off the scissor jack it'll come down to the at rest point (an inch or two into your rib cage), and keep going down, another inch or two. Or three. Due to the spring in the suspension system. The car will basically stamp you.
    At the very least go with JC's suggestion to put some solid timber cribbing under there, but you're overdue for some equipment upgrade, and it doesn't need to cost a lot.
  11. SageBrush
    11,627
    2,533
    Southwest Colorado
    Very imaginative.
    Maybe he only sticks his head under the car into a crevice, and the low line of the car runs across his neck ?
    Oh wait, never mind.
  12. xliderider
    8,055
    3,222
    Honolulu, HI
    The OP can also dig a trough in their yard or driveway to gain clearance. :rolleyes: :D
    SCH-I535
  13. ETC(SS)
    6,954
    It's unanimous so far.
    Using the 'fix-a-flat' jack isn't optimum, but it will get the job done until you can get a proper jack and/or a set of ramps.
    However (comma!!!)
    You REALLY need to get a set of jack stands while you're saving up for the new floor-jack and ramps.
    They're less than $20.
    If you're unsure as to how to use them?
    Look at a few YouTube video's.
    You'll want to look at more than one.
    Don't assume that the FIL (or people like me) are right all the time.
    We're not.
    Good Luck!
  14. Stevewoods
    655
    1,069
    Seattle, WA
    O.K.
    I get the point. It probably is not the safest way to change the oil. However, I contend that it is not the least safe.
    So, as said, I really don't do a lot on the car. I changed out the 12V, I replace the oil, oil filter, cabin filter, engine air filter, etal, but nothing too wild. And I do read the forum on a regular basis.
    So, having said that, I have no garage. No place to store ramps, floor jacks, jack stands, etc. But, I could eek out some room for one of those poor man's 2X6 things -- stacking a couple of on top of each other. Actually googled that and actually found PLANS. LOL! So, will build one of those and see if it works.
    HOWEVER, in the event I pry my wallet open and spring for a floor jack -- what "tonnage" do I need for a Prius. The front end of the Prius seems pretty heavy. Is a 1.5 ton enough?
    A 2.5 ton....or do I have to go to 3 or 4 ton. Same for jack stands...
  15. ETC(SS)
    6,954
    Easy.
    The answer is:
    Lawyers.
    The $16 Craftsman jack stands are rated at 2t (4000#), IIRC.
    Priuses tip the scales at about 3300# wet and with a junked up trunk and a car seat or two.
    Any jack stands that you buy will be sufficient for the task, especially if you buy a name brand.
    Here's why:
    Lawyers Loooooooooooooove it when a product fails, especially if it results in a really bad injury......like you watching cartoons for the rest of your life.
    If Craftsman says they're rated for 4000#???
    You can probably bet thet they'll hold a good bit more.
    Really.
    The cheap ones will work.
    If you have to store them outside?
    Keep them covered up.
    A little surface rust will make them ugly, but they'll still work.
    Good Luck!
  16. Patrick Wong
    18,200
    6,492
    You should not be competing to see how unsafe you can be. The scissors jack is a relatively unsafe way to raise up a car and you never should allow any part of yourself to be under the car if only a scissors jack is holding the car up.
    A 2.5-3 ton capacity on the hydraulic floor jack would be good. Get decent jack stands, 2 ton rating would be fine.
    Maybe you can get your father-in-law to store (or even better, purchase and store) these tools for you. Good luck.
  17. kswahl1
    kswahl1 Junior Member
    46
    I used a scissor jack to change breaks once. on a slight incline. I was a dumb teenager. no surprise it fell off the jack with the tire off. 10 years later I still think back to how horrific that accident could have been.
  18. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I'm thinking the photo of the green truck demonstrates "Most Unsafe". I believe if the chair kicks out from under the car the right side would be damaged.
  19. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    I thought the ratings is based on what the item will handle, meaning 1.5 ton jack lifts 3000 lbs. Since you will at most lift half the vehicle you look at the heaviest half to see how much capacity you need? Also, for the stands, is that not the rating per stand? It'd be a big difference. 2 ton per stand vs. 2 tons for a pair of stands.
    SCH-R530M ?
  20. kswahl1
    46
    you'll be fine with a 1.5 ton jack and stands. go two ton for piece of mind if you'd like. personally id never crawl under a vehicle on stands. get a set of ramps or make some out of 2x4's
