Safejacks Rennstands with custom Gen 3 "pinch weld" adapters
Discussion in 'Gen 3 Prius Main Forum' started by Georgina Rudkus, Jul 5, 2020.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    Just finished making custom Gen 3 Safejacks Rennstand jack stands. Custom Gen 3 Prius rennstand jacking adapters.JPG aluminum adapter close up.JPG back clearance.JPG left side jacked up.JPG
  2. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
    jack support area.jpg custom prius rennstand adapter.JPG Here's how they look like supporting the pad behind the "knife edge" pinch weld. It is the same place that the scissors jack supports. Just look at the top of the picture of the scissors jack.
    #2 Georgina Rudkus, Jul 19, 2020
  3. Mendel Leisk
    40,586
    This is where it bears:
    And even on the back end, when using the scissor jack once (with a flat), it pushed in some.
    I've never had the urge to raise one side of the car. I either do the full front or full rear. If I'm rotating tires I do both. Safety stands front or rear I place on locations near those scissor jack points, but much more substantial. I've done this countless times now, with both oil changes and tire swaps twice per year. the points I use, and they're fine with typical safety stand cradles as-is:
  4. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
    It is NOT "pushed in." The jacking block just displaced the rustproofing and the undercoating.
  5. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
    Toyota does NOT recommend jacking at the front inner attachment hinge point of the control arms. They recommend jacking only at the pinch welds and a specific point under the front cross member and the rear floor. Bending of the frame at the front control arm hinge point can alter the car's frame geometry. Jacking Points.jpg
  6. Mendel Leisk
    40,586
    Maybe not with what you've fab'd, more surface area. I know with the scissor jack, it dimples a bit. Again this was on the rear; the front jack point is maybe 50% heavier.
    For the rest, I'll respectively argue the safety stand points I use are very solid. I do jack only at the proscribed front/rear points.
    I believe the rear trailing arm hinge point is some distance back from the point I marked. You can see an oval slot both sides, that's for locking pins during shipping. Very solid, heavy guage, and double layers.
    The front points I marked are at the leading end of the main beams that run the length of the underside. I believe it was hobbit that identified those points as good with second gen, and I found 3rd gen had similar structure.
    Georgina Rudkus likes this.
  7. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
    Actually there is a area stamped in back the area behind the two notches of the "knife edge" that is stamped so that is below the rest of the back. It is approximately 30x12mm. So the jack head is perfectly sufficient. My pad provided much more surface contact area.
  8. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    Those are neat looking stands. I still feel uneasy seeing them used to lift one side of a car instead of one axle. Old habit I guess.
  9. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    I just use some hockey pucks on both the jack and jack stands to protect the jack points. No muss, no fuss...
  10. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    These work too:):
    C0EF4D9E-EABE-49A5-BC54-89C08323BAB1.jpeg AF873C2F-9447-475A-BE4A-E3E8ADB105AD.jpeg
  11. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
  12. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    I think Ray meant "in place of the hockey puck on the jack cup" without any reference to your stands.
    At least that's how I read it, and the round contour looks like it would self-center nicely in the dish of most rolling floor jacks.
    Raytheeagle likes this.
  13. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
    Duh, Lead!
    This thread is about Rennstand pinch weld adapters.
  14. Mendel Leisk
    40,586
    For a counterpoint to Toyota's "skinny knife edge with two notches":
    Alll the Honda's I've seen have similar scissor jack locations, BUT the pinch seam material is thicker, and there's an extra, heavier gauge plate reinforcement at the jacking point, about 3" wide. It projects down slightly more than the regular pinched seam, and then has a horizontal leg toeing inward, creating a flange maybe 3/8" wide. Those I have no qualms resting on safety stand cradles.
  15. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
    You would be doing that on a Tesla. It would damage the battery.
    Just made these for my friend with a Tesla 3. adapter assembled w stand on jack.JPG Tesla 3 jacking socket.jpg bottom view.JPG
  16. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
    Rear jacked up on Rennstand with my large flat plate adapter. flat plate on Rennstand head.JPG rear w Renstand head jacked up.JPG rear of car supported on Rennstand.JPG on Rennstand w tires up.JPG
