Safety Sense braking: Do the brake lights turn on?
Discussion in 'Gen 5 Prius Main Forum' started by JNemin, Jul 24, 2023.
  1. JNemin
    JNemin Junior Member
    Washington
    2023 Prius
    Limited AWD-e
    I don't have a way of checking this, but I wonder of any of the automatic braking features turn on the rear stop lamps or center stop lamp?
    Or, are the rear stop lamps hardwired to only light up when the brake pedal is depressed?
  2. hill
    8,747
    You could always get someone to follow you and record for yourself just to be sure, or take a total strangers' word on it
  3. ESh
    ESh Junior Member
    MI
    2020 Prius
    Luxury
    The brake lights turn on whenever you brake by pressing the brake pedal, by decreasing the speed on RCC, waiting on read light when HOLD is activated...
  4. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    351
    272
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    The manual suggests the rear brake lights are activated when strong regenerative engine braking is occurring
    JoeBlack likes this.
  5. daisy555
    daisy555 Senior Member
    1,715
    708
    CT
    Wouldn’t the brake lights have to come on when automatic braking features are activated. Otherwise it would be a major safety hazard for those driving behind you. Please let us know what you find out.
    #5 daisy555, Jul 28, 2023
  6. BiomedO1
    BiomedO1 Senior Member
    3,263
    1,719
    SacTown, Ca
    FWIW; my understanding of the system. No brake lamps if the system zeros out the accelerator pedal (ie. coasting). Rear brake lamps light up if ABS pump activates to apply brake force (actual braking). I haven't had a chance to test this. Just my interpretation of the system as printed in the manual.
  7. Leadfoot J. McCoalroller
    8,036
    7,515
    Pennsylvania
    2018 Prius c
    It's simpler than it seems.
    If any of the safety systems need to use the brakes to slow or stop the car, then the stop lamps illuminate.
    The safety systems don't know anything about the regen vs. hydraulic brakes- there's no need. They just ask for more braking or less braking and let the brake controller worry about the details.
  8. Jim Call
    Jim Call Active Member
    106
    110
    Asheville
    2023 Prius
    Yep, agree with your assessment and is actually what happens from observation with my XLE.
  9. fuzzy1
    10,353
    Is the specific to your Prime manual, or is it in the non-Prime manual too?
  10. BiomedO1
    3,263
    1,719
    SacTown, Ca
    I would assume it's the same system; otherwise Toyota would have to resubmit test results instead of telling them it's the same safety system; only in a different model.
    Engineering and safety testing x2 for effectively similar cars would have to be submitted to the NTSB for certification if they were materially different systems.
  11. tovli
    351
    272
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Probably this only applies to the Regen-Boost mode (pg 261):
  12. tovli
    351
    272
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Pg 331 Dynamic Radar Cruise Control - "preceding vehicle driving slower than the set speed is detected...the stop lights will come on at this time"
  13. ColoradoBoo
    ColoradoBoo Senior Member
    1,215
    798
    Monument, Colorado USA
    Good to know!
    On the same line, does anybody know the rules for the "place hands on steering wheel" warning we, sometimes get? I was driving a friend around and he wanted to see it....but no matter how long I left my hands off the steering wheel, the stupid thing wouldn't put out the warning...making me out to be a big liar!!
    Smart a** Toyotas!!! ;-)
  14. fuzzy1
    10,353
    There are enough differences, with the Prime having greater electrical capacity than the non-Prime, that I would not make that same assumption.
    At least for my Gen3 non-Plug-in, I'm not aware that regen or engine braking will ever light up the brake lights. It isn't strong enough to need to, it can't provide as much braking as downshifts in manual transmission vehicles that also don't activate the brake lights. And I'm not aware of Gen4 non-Primes doing any different.
    Driver assist features that activate the hydraulic friction brakes do need to light up the brake lights.
    #14 fuzzy1, Jul 29, 2023
