Same Prius, Not The Same MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by Dark_Prius, Sep 7, 2009.
  1. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    I have been having problems with my prius' MPG, no matter how hard I tired I get about 38MPG~43MPG. Following all the tricks from PC.
    Today, I had a chance to preform a test with my sister's prius, same package as mine with the following specs:
    2010 White Gen 3 pkg 3, 1300miles, ave 38MPG ~43MPG.
    2010 Silver Gen 3 pkg 3, 1150 miles, ave 48MPG
    First, I took my car for a 20 miles drive mixed with city and freeway, not much traffice, AC at 68 degree. I got 44.6mpg from my white prius.
    Next, I took my sister's car for the same drive, same AC adjustment and I got 51.2mpg.
    Her prius seems to be able to glide much better than mine. When I was on the freeway, her Silver prius can maintain 65 to 70mph with 50mpg. As for my white prius, when I try to maintain 65 to 70mph, my mpg meter reads below 40mpg.
    My white prius seems to have more drag and kills my mpg. I really think there is a quality problem with my prius but not bad enough to have any warming lights.
    I will try to take it to the dealer and see if they are willing to help.
    Does anyone of you out there experience the same problem?
    Please advise. Thanks,
  2. bwilson4web
    15,523
    Start with:
    • what are tire pressures?
    • what are engine oil levels?
    • was fuel - same brand, 87 octane?
    • was cruise control speed used?
    • wheel alignment? (requires a fee)
    • weather effects - temperature, wind?
    Your indicated MPG suggests speeds above 70 mph, closer to 75-80 mph. At these speeds, small changes can make significant changes in the indicated MPG.
  3. fuzzy1
    10,170
    And to verify the obvious --
    Parking brake fully released?
    Brakes not dragging excessively? (compare brake disc temperatures)
  4. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    My white prius with low MPG got higher tire pressure 42/40 vs 35/33. Not the tire pressure for sure.
    Both prius are still using the oil that came with the car.
    87 octane, no cruise control, same driver, weather is the same. As for wheel alignment, both car drives the same.
    I am going to check the brakes, the white prius seem to have more drag. I feel that I need to work on the gas paddle harder. it doesn't run as smooth.
    Definiately something is wrong internally.
  5. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Good, one item checked off.
    That's not the question. What is the oil level on the dipstick in each? What you've said is effectively, "I don't know."
    If they aren't from the same station then you have a difference. 87 octane can be very different from one place to another.
    Doesn't mean anything. They don't drive the same because yours doesn't glide well. Have the alignment checked (you get a free one in the first year.)
    Not at all definite. Possible, especially with such a large difference, but far from definite this early. See the above for a sampling.
  6. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    The white prius with low MPG oil level is correct, in between the low and top marks. I didn't check the silver prius, since it got the high MPG.
    I doubt getting gas from different station will make any different in MPG.
    The prius only have front alignment, there is no alignment at the rear. For the front alignment, only camber is adjustable. If the car drives straight, there isn't much they can do.
    One thing I got really piss at the dealer is that I took my car in last week asking them to check for my alignment. I waited 4 hours, and all they did was rotated my tires and put 30miles on my car as test drive. They didn't even put my car on the alignment rack.
    I made a complain to Toyota, if they cannot fix my prius. This will be the last Toyota I would purchase for the rest of my life.
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    drove both in same mode?? not a lot of difference between ECO or PWR but if doing a lot of small grade changes, i think it will affect your mileage.
    i suspect oil level overfill and alignment.
  8. bwilson4web
    15,523
    Alignment can be off and the handling won't seem different. As a suggestion, if you have one of those non-contact IR temperature readers, you might take a drive and then scan for 'hot spots.' A brake would be easy to detect but it could also show up as uneven tire heat.
    Sounds like an interesting puzzle. Please share whatever is found.
    Thanks,
  9. fuzzy1
    10,170
    I mentioned dragging brakes due to first hand experience. When I had this problem on a long-ago domestic, caused by a shop who claimed it was normal up until the moment the wheels began smoking, a thermometer was unnecessary. The IR radiating off the discs could be felt several inches away, and the hubs were very noticeably warm to the touch. The discs themselves were too hot to touch for even an instant.
  10. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    next time drive the exact same route, by taking it on the highway and set the cruise at the exact same speed (there is less variation for time of day with highway driving). I haven't driven the gen. III yet, but I can tell you that there are times when I can make my 25 mile trip to work at 75 MPG and other times I am struggling to make 52 MPG based on variations such as the ones mentioned above or current traffic patterns. (same car with no changes)
    In your case I am still betting on it being either Climate control use (there can be a large difference in usage just from it being sunny or cloudy), tire pressure, or type of gas. If they rotated your tires they most likely lowered your TP be sure to check only after the tires haven't been driven on in at least 3 hours.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Not to put too sharp of a point on it, but you don't sound very serious about solving this problem. Many good suggestions have been made, but mostly you have dismissed them out of hand, often citing false information. If you don't want help, why post?
    Tom
  12. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    Just to eliminate another variable, why don't you have your sister drive each car doing the same route. You are bringing an expectation to the situation. Your sister may not. If she gets the same results that you do, it may help convince your dealer to investigate further.
  13. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    WHEEL bearings?
  14. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    Thank you everyone for the valuable comments.
    Let me clarify that I have tired all the suggestions from PC before I make thsi post, such as P&G, tire pressure, oil level, weight, mode...etc. I can go on forever. As a result I got no improvements, that mean not enough improvement to reach 50mpg no matter what.
    One indication is that when I drive my white prius, cursing at 65mpg, you can see the HIS is working harder and my MPG meter reads 40MPG.
    When I cruse with my sister's siliver prius at the same speed, same road, same weather, same AC level. her car works a lot less and the MPG meter shows above 50mpg.
    How do you explain this? Many people will blame on my tire pressure, driving techniques...etc.
    How come no one have thought about not all the pruis manufactured the same quality and perform the same MPG?
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    I didn't see you confirm if the parking brake is depressed. As you may be aware, it locks at different level depending on how far you push. Make sure you kick it in all the way and another time to bring the pedal all the way back.
    You may not notice wheel misalignment until you see tire wear unevenly over 10k miles. It may drive fine to you initially.
    Why not do a simple test? Have both cars on a slight incline and then put both of them in neutral. Let them roll down and measure the distances traveled. It would be better if the same driver perform in both cars. This test will isolate the wheel alignment ,brakes or bearing.
  16. Celtic Blue
    2,224
    139
    Midwest
    Still would be worth checking.
    While I doubt it as well, it is best to eliminate it. To eliminate it, find out where she is getting her gas and try to get your next tank there. I've noticed differences in mileage with different brands of gas.
    I'm pretty sure you've got that wrong. I've never had a vehicle that lacked toe-in adjustment. And I've had vehicles that tracked straight, but with horrible toe problems.
    As far as the rear, just because it is not adjustable doesn't mean that it isn't a problem. Rear alignment problems were an issue on the GenII and weren't adjustable without a special shim kit.
    Time for a new dealer. At least half the Toyota dealerships I've dealt with really sucked. Since the one you've chosen falls under this category it would be best to try another that actually wants to solve the problem.
    Actually, nobody has said they are all identical and perform identically. Instead folks have tried to point out things that you can rule out. I suspect there is something wrong with the vehicle and only so much of it can be tested by the user. But your approach is unlikely to get you anywhere.
    Tom said it best:
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    definitely interested in what you find out. any chance of trading cars with your sis for like a week? you may think you are doing everything the same, but simply does not work that way.
    my commute is pretty much consistent. afternoons not so much, but morning is pretty much the same. i easily have 10 mpg swings. granted shorter commutes introduce greater variances caused by temperature and SOC....ya, SOC, if your drive is short enough, starting off with low SOC can kick your mileage down a few notches as well
  18. cmalberto
    cmalberto New Member
    95
    Sour Lake, Texas
    I have seen and read enough. You have proven to me that you Prius is working harder than you sisters to maintain 65 mph. Yes, it could be some of the factors that others have listed. I would think the dealer/service should be able to help with these kind of facts. If not - try another dealer, even if you have to drive a few miles. One would think they would have the correct tools to discover a mechanical problem.
    Good luck - I am watching to see a solution.
    --Mickey
  19. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Another way is to drive right behind and or beside of your sister for ten miles or so, of course the fuel consumption should be the same.
    I'm betting that for some reason your traction battery isn't connected well or something similar and your using the ICE more often than you should, pure theory, based on nothing, but connections especially grounds are easy to clean / check
  20. Dark_Prius
    Dark_Prius Member
    146
    23
    LA
    I finally convinced the dealer to look into my car. They test drove my car and obtained 40MPG city. They said something is wrong and will do more intensive test drove tonight by having one of the manager take it home and see what he obtain highway tomorrow.
    Will keep everyone posted.
    BTW, all those techniques posted on PC suppose to help IMPROVE 51/48 EPA estimates, not to OBTAIN 51/48 EPA estimates.
    tripp818 likes this.
