Samsung Galaxy Tab 7" Main head unit
Discussion in 'Gen 3 Prius Audio and Electronics' started by drunkin master, May 18, 2011.
  1. drunkin master
    drunkin master Contributing Member
    394
    103
    92
    Los Angeles
    Hello everyone.
    I finally have finished installing my SGT as my main head unit.
    The dash is not 100% finished but the concept and idea is fully implemented.
    The tab is fully functional and the sound is running though a bluetooth kit to an EQ and a pair of amps.
    I tweeked the connections so that I will have at least control of the volume using the steering wheel controls as well.
    A few apps that I like installed on the SGT are the Dash command that connects to the OBDII by bluetooth.
    Also I change up the home screen to easily access my music, pandora, movies, Navi and more.
    Here are some more pictures:
    2 people like this.
  2. drunkin master
    394
    103
    92
    Los Angeles
    Just a note that the dash command is running on demo mode at the time of the pictures. I am not going 112 MPH on the pic.
  3. GWhizzer
    GWhizzer not so Senior Member
    120
    24
    Winnipeg, Manitoba
    This is very cool. I had been looking at a Vais unit and had also thought why not just put in a tablet? How does the screen hold up in the sunlight? Can you still see it properly? Also, where did you get the bluetooth kit(s) for the audio and ODBII?
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    Nice! How is the fit? Any cutting involved?
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Interesting... how is it mounted? Daytime photo please.
  6. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    How did you get the blue surround on the shifter? Looks great, BTW.
  7. drunkin master
    394
    103
    92
    Los Angeles
    The dash kit had to be cut to fit the tablet. I wanted to make it so that I can take out the tab easily. The bluetooth kit for the obdii was purchased from the dash command site. The audio bljetooth kit was purchased from scoche. I will get done day time picks up soon.
  8. a1rjumpman23
    a1rjumpman23 Junior Member
    75
    The mod looks great!!! So would this cost more than buying a actual rosen unit installed? How do you like it so far?
  9. drunkin master
    394
    103
    92
    Los Angeles
    Check ebay. We have it for sale there.
    Search prius led shift knob.
  10. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Keep in mind - you could run one of those Chinese WINCE devices, and add an ODBII WinCE app (low cost)...
    Looks like the Pioneer Z120/130, F20/F30 series are finally starting to be hacked (WinCE) - which should open up the ODB stuff too (Hacks/Mods - AVIC411.com)!
    This is quite ingenious though :D
  11. drunkin master
    394
    103
    92
    Los Angeles
    Well Cost is going to be hard to calculate.
    Everything but the SGT was sponsored.
    I would suspect around $1,000 for all the equipment.
    Still comes out to be about the same but minus the installation and custom work.
    I have come up with a way to install the SGT, still have your radio, stearing wheel controls and use the aux in cable that comes standard on the car.
    Here it is:
    1. The custom dash will have to be purchased or done somewhere near you.
    2. Need a Samsung Galaxy Tab
    3. Take apart the stock radio's face and just have the main unit. You will have to wire the radio first and save all the stations you want first then remove the face plate to give room for the SGT and dash mount. (trust me there is enough room).
    4. mount back the stock radio.
    5. run the wires for the SGT ie. aux in wire from under the side arm rest & power.
    6. Mount the SGT to the custom dash and put everything back together.
    With this you will have full sound, control of the radio and the steering wheel controls
    have the sound from the SGT run through your aux input. Done and finished.
    Cost you only the price of the SGT and the custom mount. I would suspect the dash work will cost a minimal amount. I will have a dash kit possibly ready if anyone wants to buy it from me. Keep a look out on the classifieds.
    I will try to post pictures of this process.
  12. equake
    equake Member
    155
    Los Angeles
    Gotta say, nice work. Creative. I'm guessing that the SGT is 3G to get Nav to work. Some questions? Are you using Google Nav or some other 3rd Party Nav? Does voice Search and Commands work through the Stereo Mic/Speakers? Thanks
  13. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    Good work, but daytime picture will be helpful to understand the setup. How about CD slot?
  14. Judgeless
    Judgeless Senior Member
    1,821
    256
    Cleveland, OH
    Dash Command is $50. Does it support custom PIDS for the Prius? I have been playing around with an app called Torque. It does support custom PIDS for the Prius. Here is a pic of it monitoring MG1, MG2, ICE RPM and Temp.
  15. BrettS
    BrettS Active Member
    290
    136
    Orlando
    Hey... if anyone is considering this... or just wants a Galaxy Tablet they're on Woot today for $259.99+$5 shipping for a refurb 16G WiFi+3G.
  16. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    Which OBDII device do you have?
    It appears the developer doesn't have Prius so he couldn't test it out. It is great to see it working on Gen3. I wonder if it works for Gen2.
    MG1 RPM appears to be incorrect. It should go from +10,000 to -10,000.
    What is the "Revs rpm"? Is it the ICE? If so, it shouldn't go beyond 5,200 rpm.
  17. Judgeless
    1,821
    256
    Cleveland, OH
    PLX Kiwi
    All those gauges scale as needed.
    It is the ICE. All the gauges scale as needed.
  18. Judgeless
    1,821
    256
    Cleveland, OH
    Here is an example of the auto scale.
  19. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    It looks like you drove in EV mode. MG2 temp actually went down.
    Do you have a list of supported PID for Prius? Can you add custom PIDs?
  20. Judgeless
    1,821
    256
    Cleveland, OH
    I had my cell phone set to take screen shots every 20 seconds. The two pics above were taken at random times.
    I belive he supports all the PIDS listed in the google spread sheet posted here in the forums.
    You can add your own PIDS and show the data a million differnt ways.
