Samsung i730 with Verizon
Discussion in 'Gen 2 Prius Audio and Electronics' started by Sev, Jan 31, 2006.
  1. Sev
    Sev Junior Member
    72
    Does anyone know if the Samsung i730 Pocket PC phone from Verizon will synch with a 2006 Prius?
  2. sweden prius
    sweden prius New Member
    Stockholm, Sweden
    Not sure about the i730 but i tried my D600 end EHS720 (both samsung) with my Prius 06, they both work fine. Although tricky to upload the phonebook. Anyway, Samsung bluetooth seems to finction well
  3. Sev
    Sev Junior Member
    72
    Were those with Verizon service? Verizon is notorius for disabling some of the capabilities of Bluetooth.
  4. sweden prius
    Stockholm, Sweden
    Verizon? Hmm. I live in Sweden, Europe, and know nothing about Verizon.
  5. jsf
    jsf Member
    155
    Anytown
    If you mean add the Prius as a bluetooth device on the phone for hands free operation, then yes. I believe the phone books can be transferred, but I have not messed with that.
  6. evil_attorney
    evil_attorney New Member
    33
    Southern California
    Mine works as a bluetooth headset with the 730. I had occaisonal problems when I would keep the phone in my pocket, but when I put it in the center cup holder I never have any issues.
    I haven't figured out how to transfer the phone book.
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i dont think you will be able to transfer the phone book
  8. SirGreen
    SirGreen New Member
    75
    Hello, I just got my first Prius yesterday, 2006 Blue with the leather.
    I just wanted to know what is the best Verison bluetooth phone to get
    to work with my Prius?
  9. GregorM
    GregorM New Member
    There is way, its just not pretty. The problem is outlook formats the phonenumber, 9995551212 becomes (999) 555-1212, you have to trick outlook into storing it unformatted by using a +.
    so for local numbers, change your number via pc or phone to.
    +5551212
    or
    +9995551212
    for long distance number
    ++19995551212 (yes two +s, and a 1, your breaking outlook's dialing rule too)
    on my 2006, it sends the + signs but both car and phone ignores them and dials properly.
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    Ahhh, this i believe. should have known a problem would involve microsoft somehow...
  11. GregorM
    GregorM New Member
    found another/better way, for the i730. probably all winmobile phones. The problem with the first way i found is caller-id doesnt work. the i730 sends the prius the phonenumber as it has it in the contact list, not as caller-id sends it, so...
    On your phone, if you goto to settings->system->Regional Settings and pick a language/country where US numbers dont trigger formatting the number, like English (Zimbabwe) you can enter the number correctly in the contacts like caller-id would send it. i.e ten digit with area code - 9995551212. it has to be 10 digits for local. the dial rule is still broken, so you need to add a 1 for longdistance, possble a +1, havent recieved a long distance call yet. but web searching suggests a +1 instead of a 1 might be needed for caller-id to work on long distance
    beam your contacts then change the Regional Settings back. as long as you dont edit the phone number field, it will stay unformatted. when you sync it the pc will still format, so the down side is you have to change a phone number on the i730, not the pc, but the caller-id will work.
  12. kellsworthington
    kellsworthington New Member
    23
    When I spoke to samsung, they told me that none of the Samsung phones work with the Prius. Something about using a different bluetooth chip.
    Some people say they got their samsung phones to work. I had 2 samsung phones and neither of them worked with my prius. I had to get a sony ericsson, which works fine.
    I will never buy samsung again.
