Sandy Munro swings a sledge hammer
Discussion in 'Other Cars' started by bwilson4web, Sep 11, 2023.
  1. bwilson4web
    15,511
    Well worth the time:
    49,371
    couple things, the casting is not fixed in place, maybe put it against a wall?
    the second swing on the rear casting looked like a whiff
  3. Mendel Leisk
    38,643
    Yeah totally different, much less inertia, with the second "subject". I lost interest.
  4. bwilson4web
    15,511
    Watch it to the end where Sandy points out:
    'We make engines with a lot of explosions going on inside from aluminum castings. Not pieces of stamped metal welded together.'
  5. John321
    John321 Senior Member
    1,197
    1,195
    Kentucky
    Much prefer NHTSA methods and data!
    #5 John321, Sep 11, 2023
    FalconSeven likes this.
  6. bisco
    49,371
    i'm not doubting the superiority, just the sledgehammer
  7. Mendel Leisk
    38,643
    Just technical but it bugged me: if you’re employing full face protection, flip it down before you start swinging.
    still, I’ve been there…:unsure:
  8. bwilson4web
    15,511
    Some may not understand:
    Others will appreciate the subtle humor.
  9. bisco
    49,371
    i'm 68, i can commiserate
  10. Trollbait
    11,503
    When an engine block is damaged, it is replaced, not repaired.
    How is that going to work out with these frame pieces?
