Sanity check on L2 charger
Discussion in 'Prime Plug-in Charging' started by PerryD, Apr 13, 2022.
  1. PerryD
    PerryD Junior Member
    27
    34
    Near Boston
    2022 Prius Prime
    I have a security light on a pole by my driveway, and my local electric company said it'd be fine to drop a connection off of it into a standalone socket, on a separate meter. I'm planning on buying a Level 2 EVSE such as the Lectron line to plug into the socket.
    There's no discount on the rate (it is currently 14.6ยข / kWh), but the electric company said they'd do the hookup at no charge. My startup cost is just the riser with the socket under a weatherproof hood, a few brackets, the EVSE, and an electrician for a few hours. There's a $10/month charge for the meter, unfortunately.
    Anything I'm missing or misunderstanding?
  2. Salamander_King
    Salamander_King Senior Member
    10,975
    8,870
    New England
  3. PerryD
    27
    34
    Near Boston
    2022 Prius Prime
    The security light and pole are relatively far from the house, and we want to mount the EVSE at the pole. A side benefit is that I'm all set with a meter socket if the town offers a separate rate for EV charging.
    I'm in a small town with a small electric company, the engineer I'm working with is psyched as no one has asked to do this sort of thing yet in town (he also is the guy who approves the plans, so that's a plus).
    [edit] I don't have 240V service in the house currently, and it'd be a significant cost to set one up, according to my electrician. The pole already has 240V service and the electric company is willing to tie into it at no charge. I still have to pay my electrician but it's a much simpler (and shorter) job.
    Salamander_King likes this.
  4. Salamander_King
    10,975
    8,870
    New England
    Got it. Sound like a good plan. Yeah, a separate meter might come in handy if you want to rent out the charger to other EV owners.
  5. bisco
    49,519
    will the evse be safe?
  6. BiomedO1
    BiomedO1 Senior Member
    1,485
    803
    SacTown, Ca
    wouldn't it be easier to set it up as a public charge point so you don't have to bear the cost and place your equipment at risk. The city/township can claim that it's part of their new green initiative and maintain low charging fees; ekk out a small profit. Win win all the way around; politicians love taking credit for this kind of crap.
  7. PerryD
    27
    34
    Near Boston
    2022 Prius Prime
    We're pretty private people and would not take well to folks plugging in at the end of our drive :^)
    The own's doing great with EV, we have eight chargers scattered around town right now, and there are more on the way. About half are set to free service.
  8. BiomedO1
    1,485
    803
    SacTown, Ca
    Sorry, didn't realize it was at the end of your drive.
    Public lamp post out here are located on the sidewalk; usually on the property line - between houses. Usually, half the distance between drive ways. ;)
  9. PerryD
    27
    34
    Near Boston
    2022 Prius Prime
    An update, the quotes from local electricians to install at the pole were absurd, $2k+ to mount a socket on a board. The meter socket is about $600 of that price.
    I opted to instead pull a 20A line from the house panel and mount the plug on the side of the house. It's still ~$800. I'm buying a Lectron 16A charger to plug into it. This doesn't future-proof the install, but I don't intend to buy another EV for the next few years, and price is a factor.
  10. Salamander_King
    10,975
    8,870
    New England
    I can sympathize with you. A quote I got from an electrician years ago to put a 240V outlet in our garage was ~$10K. Needless to say, I have not installed an L2 charger for my PP. But, I do have an L2 charger already. It was on special discount and with the local utility rebate, was 50% off. Tried using it once with an extension cord and adaptor to our dryer plug. It works... but the setup is too cumbersome to be used as a permanent solution.
  11. BiomedO1
    1,485
    803
    SacTown, Ca
    I'm not sure your aware; but your OEM charger is 110-240VAC auto-switch compatible. You just need to create a NEMA 6-20p to 5-20s adapter pigtail. I'm assuming your electrician is installing a NEMA 6-20 socket w/outdoor weatherproof outlet cover.
    But if you insist on buying a secondary charge plug. https://www.napaonline.com/en/search?text=schumacher%20ev%20charger&referer=v2 These are ship to store or your home - good till the EOM.
    jerrymildred likes this.
  12. jerrymildred
    jerrymildred Senior Member
    11,516
    14,120
    Tampa, FL
    That's insane!!! Meter sockets cost under $100 unless you're getting something huge and industrial.
    Good thinking. ;) But you said in an edit to the OP that your house doesn't have 240V. (Which I thought was very strange, btw. o_O)
  13. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    In my case, I was able to get a 240V outlet installed in my garage for $1,000. I purchased a JuiceBox Charger for $500. My state rebate for my first Prime of $1,500 covered everything.
