Sat Nav - Night Mode
Discussion in 'Gen 2 Prius Audio and Electronics' started by *Goldfinger*, Feb 21, 2015.
  1. *Goldfinger*
    *Goldfinger* Junior Member
    Sheffield, England
    Does anyone know if it's possible to stop the Sat Nav display going into 'Night Mode' (dimmed display), when putting side lights on? I don't mind it doing it when I put the main headlights on.
  2. magnumrtawd
    magnumrtawd Member
    305
    72
    Toledo,Ohio
    My 2010 will stay bright if i set the dash lights to the brightest position.
  3. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    The UK Prius does not have the thumb wheel brightness control that the US Prius does. It has instead a system where buy you push the mile/kilometer button while the lights are on to step through various brightness levels of the displays. Not exactly intuitive. The satnav at night goes to a black background irrespective of the brightness level set.
    There is a photo cell on the top right of the dash "near the screen" that assesses night and day adjusting the satnav screen background. From memory there is a setting for altering this when the satnav is being used.
    "Goldfinger" weather permitting I will check, and come back with instructions.
    John (Britprius)
    #3 Britprius, Feb 22, 2015
    *Goldfinger* likes this.
  4. Tideland Prius
    16,445
    DISP --> DAY Mode
  5. *Goldfinger*
    Sheffield, England
    Than
    Thanks, if switched into Day Mode will it automatically go back to Night Mode when I switch lights to main beam?
  6. Britprius
    5,194
    1,918
    I do not think it will it will just stay in day mode. It may go back to normal operation after turning off the car, and lights something I have not tried. I did not come back with the answer as "Tideland" got there first.
    John (Britprius)
    Tideland Prius likes this.
  7. *Goldfinger*
    Sheffield, England
    Thank you both, much appreciated, can' t believe I didn't see that option when I was playing around with the settings :)
    Just in case anyone looks up this thread at a later date - the 'Day Mode' option only appears when your side or headlights are switched on.
