sat radio character limits
Discussion in 'Gen 2 Prius Audio and Electronics' started by jfarmakis, Jul 22, 2008.
  1. jfarmakis
    jfarmakis New Member
    ohio
    new 08 Prius w/pkg 5...getting dealer installed Sirius
    part # is pts31-47060
    Question is what is the character limit of this? I've heard some are 10 & some are 16. If it's 10,which one is 16?
    Thanks?
    Jim
  2. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    i do not know the character limits
    DO NOT BUY THIS UNIT
    tell the dealer you want the cheaper TOY-SC1 interface and scc1 tuner
    its a newer part and only $146 for the parts
    the dealer will probably want the $500 msrp to install the older pts31-47060 part
  3. Rest
    Rest Active Member
    1,210
    53
    CA
    The dealer unit is limited to 10 characters. Buy the Directed Electronics TOY-SC1 and SCC1 for around $150, then install them yourself. It is easy and you will save a bunch. The only difference is the Directed Electronics version has a 16 character limit and you can't use steering wheel controls for changing presets, instead it changes channels.
  4. hammy
    hammy Prius Addict
    53
    Massachusetts
    I would repeat what REST just said.
  5. rwa46
    rwa46 Pilot
    38
    south central Texas
    1!! install either unit yourself. have done both. 2 hr max for novice. the toyota unit $260 allows all controls to work. 10 characters. having the controls work is the most important vs 10 or 16
  6. Rest
    Rest Active Member
    1,210
    53
    CA
    The only control missing would be scrolling between presets. That is hardly worth the extra money.
  7. rwa46
    rwa46 Pilot
    38
    south central Texas
    really going from ch 6 to ch 75 alone in car. i like have ch's i want a click away.
