Sat/radio didn't work after wash
Discussion in 'Gen 3 Prius Audio and Electronics' started by tinaprius, Jan 7, 2011.
  1. tinaprius
    tinaprius New Member
    26
    SC
    Took my car to one of those no-touch car washes and after I pulled out the sat radio would come in and out but would not come in clear. I switched to FM and it was full of static. I parked the car in our garage and about 30 minutes later I checked it again and it was working. Any ideas?
  2. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    Water went somewhere.
  3. Joe166
    Joe166 New Member
    720
    96
    South Florida
    I have an idea. Don't do that again. Apparently some water got in where it wasn't supposed to go and then dried or dripped out. Frankly, if it were my car I would probably worry that this might happen again and again and more often as it aged and I would try to track it down and have it fixed, but the easiest solution is to avoid high pressure washes and if you do go in them, resign your self to bad (or should I say badder) radio for a short time.
    You could mention it to the dealer every time you bring it in. Maybe someone else in the Toyota hierarchy has figured something like this out and they might post it on their computer system. Not likely, but possible.
  4. HanSolo
    HanSolo Junior Member
    23
    Bettendorf, IA
    This just happened to me. I removed the antenna before the automatic wash and screwed it back in after. Now the xm radio is in and out or silent. I'm going to clean the antenna hole then see.
  5. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    I have a JBL system with Sat radio, no Nav. Have been through these touchfree wash stalls several times......never had this problem.
  6. HanSolo
    23
    Bettendorf, IA
    Problem went away. I dried off screw in antenna connection but it didn't seem wet. Weird. Thanks for the thread.
  7. Pri4Us
    Pri4Us Junior Member
    82
    Tierra Buena, CA
    Just a thin film of soapy conductive moisture could short out the antenna terminal. At commercial car washes it's common for attendants to temporarily remove the antenna so their roller brushes don't tear it off. Unfortunately, their actions may leave the open antenna receptacle full of soapy/waxy water.
    There are a couple of easy solutions to this potential problem.
    (1) Unscrew and remove the rubber ducky portion of the antenna yourself and insert a tight-fitting plastic/rubber plug or a short nonconductive screw with an identical thread pattern before going to your local car wash.
    (2) If your antenna does short out due to trapped moisture you can remove any residual soapy water or contaminating residue at the bottom of the receptacle with a Q-Tip. Then blow dry the receptacle thoroughly with pressurized (canned) air before rethreading the antenna.
