Satellite radio installation
Discussion in 'Gen 2 Prius Audio and Electronics' started by jayfinke, Jul 5, 2005.
  1. jayfinke
    jayfinke New Member
    Atlanta
    This is my first post, but I've been following this topic for a few weeks.
    I just recieved a Sirius tuner and fit kit. I downloaded an excellent set of instructions from Eddie in Cleveland. The only problem, though, is you have to disassemble the entire dash. I don't think so. I have seen a few references to just removing the glove box and maybe one vent. Has anybody done this, and if so, I'd be grateful for some details. Or any comments, for that matter.
    Jay
  2. Kyle Pehrson
    Kyle Pehrson Member
    122
    S.L.C. Utah
    It is very easy it snaps together you have to pull the vents out first then the upper and lower steering collum covers than you will see the bolts that hold the display and the radio in.
  3. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Look for instructions for XM satellite, as the installation should be the same. I believe the shortcut is to remove the bolt holding the gateway ECU, then you can just about reach behind the head unit and install the accessory harness plug into it.
  4. jayfinke
    jayfinke New Member
    Atlanta
    Thanks for your comment. Maybe it's not as hard as I thought. But the devil is in the details, and I still think I need some. As a tech, this is probably child's play for you, but I'm not quite so confident. Do you have any hints or tips to keep this installation as simple as possible (other than pay someone to do it).
  5. jayfinke
    jayfinke New Member
    Atlanta
    I just now discovered that siriusprius.com is selling a kit with tuner and instruction dvd along with an antenna upgrade. To my delight, they are also selling the dvd alone or in an upgrade kit with the antenna, which I immediately ordered.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(jayfinke\";p=\"104775)</div>
    sounds like PriusXM folks covering the Sirius side too.
  7. Jon
    Jon New Member
    57
    Whippany, NJ
    Hi All,
    Yes, now available:
    SiriusPrius
    www.siriusprius.com
    This includes an upgraded antenna and our new 1-Hour DVD. I think our Sirius DVD is even better than the XM DVD.
    The reason we offer the upgraded antenna is because the OEM antenna is worthless. It's also incredibly ugly and large. I use it as a tire chock.
    We also sell just the DVD, or a Buy-It-Yourself bundle which includes the DVD, the upgraded antenna, and Dual-Lock fasteners.
    Thanks for the mention, Evan, Jay.
    -Jon
    PriusXM - www.priusxm.com
    SiriusPrius - www.siriusprius.com
  8. efusco
    19,891
    1,192
    Nixa, MO
    Yup, both have copyrights of "Internection" at the bottom of the page.
