Saving gas with lighter wheels
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Prius Happy, Oct 2, 2009.
  1. Prius Happy
    Prius Happy New Member
    114
    Irvine, ca
    This is really neat...
    SSR Wheels
    I wonder how's the difference. Does anyone have these wheels on their cars yet? I like how the Type F looks like.
  2. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  3. hill
    8,640
    If that were an exact science, the Gen III's 17" rims would have to weigh some 20 pounds more than the other OEM's ... as the 17" rims cause about a 1mpg hit, right? Hard to believe they're that much heavier.
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Unless I am mistaken, the 17" wheels use different brand tires in different widths than the 15 " wheels. That is changing WAY more variables than the same tire on different weight wheels. Toyota also makes other changes in the suspension, as well.
  5. a_gray_prius
    2,927
    783
    IL
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Now these in black would look sweet on "Baby".
    They weigh less than the stock oem wheel.
    PERFECT!!!
    Thanks for the find!!!
  7. Matt Herring
    Matt Herring New Member
    421
    51
    North Andover, MA
    Two issues with these rims...
    The larger gaps in the rims most likely increase drag compared to the stock rims essentially canceling out the mpg boost from decreased weight of the rims...
    Unless you are purchasing these rims for the look rather than the mpg gain...it will take longer than the lifetime of the car for the mpg gain to cancel out the cost of the rims...
    Clearly, lighter rims/tires increase mpg and LRR tires help increase mpg as well...but at what cost? Guess it depends on what you are going for...the look or the mpg...usually not easy to get both.
  8. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
  9. a_gray_prius
    2,927
    783
    IL
    Most modifications done to your Prius will never pay back the cost of doing the mod in fuel savings.
  10. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    So most of us do it just for the fun of it. :D
  11. KK6PD
    4,003
    946
    118
    Yeah, what he said!!!!:)
  12. a_gray_prius
    2,927
    783
    IL
    I didn't spend 3 grand on rims, tires, and labor to save gas.
    I need to change my title to "not a hypermiler cheap hawk"
  13. Solscud007
    Solscud007 New Member
    59
    Nyack, NY
    do not know if this sheds new light to the topic. Rota wheels makes a knock off of the Spoon Sports wheel called Slipstream.
    15x6.5 5x100 offset +40 or a +45 depending on your preference.
    +45 will put the tires closer toward the center of the car.
    +40 will put the tires a hair further away than stock.
    They weigh only 11lbs and cost about $300-$400 depending where you get them. That is for all 4. Im a huge fan of Rays Eng and Volk rims, but the cost far out weighs the "performance" in terms of what we want to get out of the wheel for the Prius.
    The Slipstreams may be an alternative to affordable light weight wheels. Im just not sure if they really would help with MPG.
  14. Tekdeus
    Tekdeus Shifted to Green
    151
    Vancouver
    Going from a 15" to a 16" rim puts more rim weight further out, causing more rotational inertial resistance, possibly canceling out the reduced weight of the 16"+ wheels.
  15. sidecar
    sidecar Member
    342
    44
    Australia
    surely the offset doesnt make much more difference than additional load on the wheel bearings?
  16. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I get that if the lighter 16 inch wheel design were an otherwise identical identical but thinner cross section version of the 15 inch wheel, anything over a 12% weight reduction would be a benefit in total mass moment of inertia. However, I wouldn't expect the design of a performance oriented wheel to be as weight efficiently as inept as the design of a mass market production car wheel, so a smaller weight reduction would result in a reduced wheel MMI.
    What do you get?
  17. GloryThief
    GloryThief Junior Member
    59
    The Westside
    2013 Prius v wagon
  18. Tekdeus
    151
    Vancouver
    I'm not sure how to calculate this. Is it possible to figure out just with math alone?
    This photoshop picture below looks pretty nice. Are there springs available for the Prius that drop the ride height but keeps the stock springrate/stiffness? Lowering ride height also reduces frontal area and MPG from what I've heard.
  19. losede
    losede New Member
    u s a
    The thing you got to look for is the rust, if there is rust anywhere on the car than its bad. And RWD in snow can be really fun, you can drift etc........ But since you dont do that then its good. And its a V6 so its gona eat up more gas. I would say get some headers, cat back and air intake, and do some body mods and keep the Jetta.
  20. GloryThief
    59
    The Westside
    2013 Prius v wagon
    delete post:
