Scan gauge 2 and prius Trans FLuid temp
Discussion in 'Prius v Accessories and Modifications' started by dangarlepp, May 5, 2016.
  1. dangarlepp
    dangarlepp Junior Member
    central florida
    I guess the prius (any prius) has no Trans fluid temp sensor. I tried all 3 general Trans fluid temp codes for Toyota and none work. Anyone have any info on this.
    Thanks
    Dan
    2016 Prius v
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  3. dangarlepp
    central florida
    Thanks for the reply, I have been watching those temps. They get pretty high, into the 200 + degrees. At that temp the trans fluid would break down quick.
  4. Mendel Leisk
    38,727
    Are you grill blocking by any chance? Just curious. Yeah, maybe tri-yearly transaxle fluid changes warranted, regardless of distance. Fairly cheap and easy.
  5. dangarlepp
    central florida
    No grill blocking, I live in Florida. I had the scan gauge in my Prius c when I was monitoring the MG1 MG2 temps, when I saw temps at 200 degrees I wasn't sure if that meant the trans fluid was 200. I keep an eye on trans fluid temp because I ruined a regular auto trans by letting the fluid get to hot. Didn't realize, I was delivering mail, the slow stop and go heats up the trans fluid, the fluid turned black and killed the trans in a 1996 corolla wagon. I'm due to change the fluid soon in the C. Thanks for your help.
    Dan
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    In that sense, you do not have an automatic transmission, you have a one speed manual with no clutch.
    A 'normal' automatic has a torque converter which allows slippage between wheel speeds and engine speeds, all that slippage becomes heat. In the Prius transaxle nothing slips*. so there is MUCH less heat from friction when accelerating. Its heat is from the motor/generators, not friction.
    I found this accurate and hilarious. What it calls a fluid coupling we now call a torque converter
    None of this happens in a Prius.
    *Computers rotate two electric motors and the gas engine at different speeds to smoothly drive at any speed.
  7. dangarlepp
    central florida
    Cool OLD video.
    It still bothers me that the MG1 and MG2 temps are so high (210 to 215F).
    So to ease my mind, your telling me these high temps are OK right?
    If you guys have a chance, check your MG1 and MG2 temps and let me know what you see.
    Thanks
