Scan gauge and No codes ?
Discussion in 'Generation 1 Prius Discussion' started by JamesGilmore, Jan 18, 2019.
  1. JamesGilmore
    JamesGilmore Junior Member
    palmdale ca
    2002 Prius
    I
    I bought a scan gauge ll and have it connected and set up in my 2002 prius. I seem to be getting codes thrown but the sca n gauge says NO codes pending. and when I pres clear codes it will clear the code then It come back... and clue why I cannot see any codes ?
  2. ChapmanF
    18,615
    You can use a ScanGauge to read codes from the HV ECU, but not by default; you have to program in the right "XGAUGE"s for it, which vincent1449p managed to work out 9 years ago or so. Have you found those?
  3. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    You'll be better off with getting Techstream and a laptop running XP. I've done lots to my gen1 and would have struggled with some problems without Techstream.
  4. JamesGilmore
    palmdale ca
    2002 Prius
    I
    I may well go to that but the car seems to run ok with random codes every few months....has yet to repeat what ever I bought the scan gauge for in december.....
