Scan Gauge II - Is it worth the money?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cary1952, Aug 31, 2013.
  1. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Thinking of getting SGII. Is it worth the money or just more fun to play with. Can you ever recoup the cost of it in savings? Thanks!
  2. Fluxuated
    Fluxuated Member
    133
    53
    Guelph, ON
    It's not a Miracle device, but it gives you all the tools you need for better fuel economy, as well as XGauges which you can program custom readings, and use to disable Backup beep and seatbelt beep, should you choose. It can also recover "Check Engine Codes" and clear them. So if the car pops a code, you'll know right away what it is, and will be able to look it up.
    I find mine to be a necessity. I use it all the time, every time I drive the car. Will you recover all the savings? Probably not, since your no doubt doing really well by driving a Prius, the savings gained will take a LONG time to recover the cost of the device.
    I highly recommend it. And you can use it in another other vehicle. I've used mine in my 2005 Corolla, 2009 Lexus RX350 and 2011 Prius Liftback.
    Good luck! (I got your message, will post pics of my setup shortly)
  3. Mendel Leisk
    40,584
    I initially mounted it on the dash with loops of masking tape on the underside, as a stopgap fastening system, meaning to switch to the supplied adhesive-backed Velcro strips. It held position so well I stayed with masking tape. I've pulled it off to clean the dash, and replaced the tape once or twice, does not leave a residue.
    In a crash it would likely brake loose, the Velcro would be better in that regard, but it is very light.
    The cord I just run down from the right side, down to the OBD port.
    Here's a pic of the location:
    51,154
    for the 9 years i've been driving prius, i thought about buying one. and i think my mpg's are right up there just driving slowly and p&g. i do think it would be cool at first, and useful at other times.
  5. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Here's my SG location. There is a trick to making it stick.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    I think the SGII or another Prius specific OBDII device is certainly worth the money. The few times that I have had mine disconnected I have been at a loss while driving. I am always monitoring one area of the hybrid system or another. In this hot weather I am monitoring HV battery temps closely.
    Plus you can turn off reverse beep, etc. You can also read Check Engine Light DTC's and reset the Alarm and Fault messages.
  7. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    YES! It is :cool:
  8. orenji
    orenji Senior Member
    5,886
    3,487
    Can you explain how it hooks up to the car and gets it power?
  9. Drdiesel
    585
    152
    Monterey CA
    Plugs into the OBDII port and get's it's battery power from pin #16
  10. priusincc
    priusincc Member
    332
    16
    NV
    I like it for the RPM and water temp readouts. It also, gives you a clue on how much it will take to fill up. I transferred mine from my old ride. It does duplicate the average mpg, cost-per-mile, and miles-to-empty info the Pri already has. It apparently can give error codes. but I have never had to use that feature.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    just think how many miles you can drive with 100+ bucks...
  12. Drdiesel
    585
    152
    Monterey CA
    It's expandable too. Just program it and the X-Gauge setup will read any data on the buss.
    I transferred mine from my C to my C-Max. I have HV battery temperature and SOC as
    well as cabin temperature programmed to display. It will read fault codes and clear them too.
    It's a great tool for a great price. You'll never wonder whats happening if the check engine light
    comes on. You can read the codes and know what the PCM is reporting. This can keep you from
    paying a dealer $130 bucks to reset the system for a loose gas cap problem :eek:
    priusincc likes this.
  13. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    I use a tablet, a bluetooth ODB adapter, and Torque, instead. About the same price, and lots more useful in lots more ways.
  14. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I had the tablet already (Nexus 7) so I shelled out $20 at Amazon for the bluetooth ODB adapter and downloaded Torque app at the Google Play store... and I have almost all the readings I could hope for at $20 outlay.
    Robroy likes this.
