Scan Gauge II Question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by chado1000, Feb 23, 2011.
  1. chado1000
    chado1000 New Member
    16
    I could have sworn that I read somewhere on here how you can use the Scan Gauge II to change the reverse beep, but like they always say I cant find it now. Has anyone done it?
  2. dropshot
    dropshot New Member
    28
    Using the proper codes from the GEN III XGAUGE master list add the Reverse Beep disable code to the custom XGAUGE codes then set it as an active gauge to monitor and it will set it. You only need to do that once, then leave the code stored for future use if you don't need more XGAUGE settings than the Scangauge can store (24 I think). I set both the disable and the query gauges to confirm it worked, as well as putting it in reverse and hearing only one chime. :rockon:
  3. caffeinekid
    caffeinekid Duct Tape Extraordinaire
    334
    44
    Houston
    You beat me to it!
    The list really should be a sticky on the forum header.....unless I am blind and just don't see it. :eek:
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ from what I have seen, stickies don't seem to help that much. :(
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  6. xamnosidda
    xamnosidda Junior Member
    61
    Celebration, FL
    I have a ScanGauge II but I purchased it like 4 years ago and it hasn't been upgraded. Can I still disable the backup beeping or do I need to send the unit in for the $25 firmware upgrade?
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    It would help to know your firmware version and whether can do XGauges at all.
  8. xamnosidda
    61
    Celebration, FL
    I ended up calling the company and they confirmed my ScanGauge would work. I went straight to the Prius, put in the codes, and within 10 minutes I had the reverse beep set to one beep and turned off the seat belt beeping completely.
    Totally painless. Thanks everyone!
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Ya just gotta love it when a plan comes together! :D
  10. xamnosidda
    61
    Celebration, FL
    You got that right. The car is so much more pleasant now.
    I don't know about the rest of you but that faster beeping seat belt warning is enough to about make me go postal. :mad:
  11. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    That is why I left the seatbelt buzzer on, I want putting on their seatbelts to be less unpleasant than not putting them on.
    radiocycle likes this.
  12. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    Was that a direct translation from Japanese to English? :)
    Precisely my rationale for not disabling the reverse beep... knowing that I am in reverse is less unpleasant than crashing into the car behind me when I've left it in reverse at the traffic light!
  13. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    English is my Second Language, I wish I had a First Language.
