Scan gauge SOC HV battery reading?
Discussion in 'Gen 2 Prius Technical Discussion' started by icarus, Jan 5, 2008.
  1. icarus
    icarus Senior Member
    4,884
    976
    earth
    Sorry if this has been answered before, but I did a search and can't seem to find it.
    I have sparkling new scan gauge and I have a couple of questions.
    How do you get it to display HV battery voltage, and State of charge?
    The manual suggest their web site, (which is no help!) and users groups,, I guess that's us!
    Thanks
    Icarus
  2. icarus
    4,884
    976
    earth
    I answered my own question. There is an error in their PDF so that the Prius page doesn't show up. If you view it through HTML, you can read the codes. The numbers don't line up properly with the proper heading, but you can work your way through it.
    Icarus
    PS. HV battery Voltage and State of Charge are kinda cool to see.
  3. Rest
    Rest Active Member
    1,210
    53
    CA
    The code for SOC doesn't work for everyone. Many of us can't get SOC to show up and the ScanGauge people can't figure out why it doesn't work for everyone.
  4. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    icarus,
    how did you get it to show up? I;ve looked for a way on mine, but i can't find it either. Help?:eek:
  5. icarus
    4,884
    976
    earth
    David,
    It is far from intuitive but assuming you have the adanced X-gauge function here is what you have to do. Follow the instructions in the book to get to the x-gauge functions. They you go into edit. It will then require you to enter a series of codes for each additional function. I added Horsepower, HV battery voltage, and HV battery state of charge.
    THE ONLY WAY I COULD GET THE CODES WAS HERE:http://72.14.253.104/search?q=cache...+codes&hl=en&ct=clnk&cd=8&gl=us&client=safari
    If you go to the normal "support" section of the scan gauge site, it will send you a PDF that is lacking all the pages that are relevant. I was able to find the above link after a long series of searches.
    Good luck,
    Icarus
    PS If you can't get them I'll post them here. In fact perhaps I'll try to post them later anyway.
  6. icarus
    4,884
    976
    earth
    Here is the code lines from the above link.
    On the scan gauge site, the numbers DO NOT line up properly with the appropriate function, but the numbers are correct If you follow the prompts correctly it will be come clear what number goes where.
    Prius HV battery state of charge
    TXT 07E321CE
    RXF 056186CE0000
    RXD 3008
    MTH 000A00020000
    NAM SOC
    Prius HV battery voltage
    TXT 0033
    RXF 0100023B0000
    RXD 2010
    MTH 000100010000
    NAM BTV
    Horse power
    TXD 00
    RXF 4008000000
    RXD 0000
    MTH 000A00170000
    NAM HPR
    I hope I got these right! If not try the link!
    Icarus
  7. Rest
    Rest Active Member
    1,210
    53
    CA
    My mistake, it's not SOC that I can't get, it is BTV.
  8. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    This documentation difficulty does not bode well for people being
    able to easily get battery *current*, which is what you really
    want to monitor instead. It baffles me why Ron et al only went
    for voltage when they were sniffing out the PIDs, when they
    could have grabbed a whole slew of battery-ECU stuff at the time.
    _H*
  9. icarus
    4,884
    976
    earth
    I wrote to linear logic to ask if they had any intention of offering inverter temp, or battery temp or any other items in new releases. I await an answer.
    Icarus
