1. donalmilligan089
    239
    22
    virginia usa
    My scan gauge has begun to go blank every minute or so. Any fix?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Any possibility that the Setup has changed back to the default values for a gas engine and is turning off each time the ICE shuts off?
  3. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    Make sure FUEL type is set to HYBRID.
  4. PriusTech
    PriusTech Active Member
    261
    120
    Reno
    Is the main connector snug? Sounds like you are losing power.
  5. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Also make sure that under the Advanced Setup Parameters that the SLEEP EVENT is set to NO COMM.
    The default value is 0 RPM which will cause the ScanGauge to go blank each time the ICE stops.
  6. donalmilligan089
    239
    22
    virginia usa
    problem solved. The hybrid was not applied
    dave77 likes this.
