scan guage II keep going blank help !
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by don m, Apr 28, 2015.
  1. don m
    don m Junior Member
    meadowview va
  2. fuzzy1
    10,149
    Do you have it set for Hybrid mode?
  3. don m
    don m Junior Member
    meadowview va
    I had not changed it for years I did disconnect 16 pin connector. maybe that's it i hope i'll see have lost user manual .can I get another ?
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Yes, make sure it's in hybrid mode. If you are in RPM mode, it is designed to shutdown when the engine RPM is zero. In hybrid mode, it will shutdown when activity drops on the CANBUS.
  5. fuzzy1
    10,149
    Yes, online: ScanGaugeII User Manual : Linear Logic
