Scan Tool / OBDII / Mini VCI - Which Do I Get?
Discussion in 'Gen 2 Prius Main Forum' started by Swurlo, Aug 4, 2025 at 11:02 PM.
  1. Swurlo
    Swurlo New Member
    Wednesday
    Melbourne
    Hi all! :D
    I've recently purchased a (used) Toyota Prius, GEN II - 2007, NHW30
    The check engine light is flagged - and I've been told that the vehicle had a historical error code -
    "CATALYST CODES P0420"
    I've been quoted by Toyota $187 AUD to have a scan tool place on it again,
    I've got the sneaking suspicion it's a faulty or aging oxygen sensor -
    Moving forward, I'm not too keen on paying out every time I'm hoping to diagnose something,
    What is the best scan / diagnostic tool for the Toyota Prius available on the Australian market?
    I'm hoping for the scanner to be able to pick up on oxygen sensor information, airbags - just about everything that a Toyota mechanic would be able to - but within reason if its pricey
    Hope you can all help me with this one! :cautious:
    Swurlo
  2. Tombukt2
    Tombukt2 Senior Member
    12,363
    2,192
    Durham NC
    No it's not an. 02 sensor. It is probably you catalyst .. Autel ap200 will cover you . Unless you're a real Keen meccie.. I use the ap 200 more than I pull tecstream laptop down these days. Good luck . The catalyst is just below the threshold of being able to do its job . This is a self test the car produces at random
  3. Brian1954
    Brian1954 Senior Member
    1,872
    738
    South Central PA, USA
    Read post #1 and then scroll down to post #37 in this thread, https://priuschat.com/index.php?posts/3246758
    You want to choose a scanner that is capable of communicating with all the ECUs in the car. The Autel AP200 is a good choice. Be advised that you will need to login to the app when you want to use it, so you need internet access.
