ScanGageII Prius scan codes
Discussion in 'Gen 2 Prius Accessories & Modifications' started by psibill, Oct 28, 2007.
  1. psibill
    psibill Junior Member
    55
    Just got the revised SGII with the Xgauge feature. I input the two that are listed on their website for Prius, SOC and BTV (which I presume to be the traction pack voltage).
    The SOC works, but the BTV does not (just stays at a blank value). This is on an '06 model.
    Wondering if others are having the same problem, and/or if some have gotten it to work, and on which model year.
    Thanks.
    --Bill
  2. Rest
    Rest Active Member
    1,210
    53
    CA
    My understanding was that the SOV and BTV was for the Hybrid battery pack. I haven't added the codes to my SG2 with the new firmware yet. Have you tried re-entering the code?
  3. psibill
    55
    <div class='quotetop'>QUOTE(Rest @ Oct 28 2007, 01:42 AM) [snapback]531500[/snapback]</div>
    Didn't try reentering from scratch, but I did verify all the codes matched the .pdf on their site.
    --Bill
  4. Neicy
    Neicy Member
    834
    Wakefield, MA.
    <div class='quotetop'>QUOTE(Bill-psi @ Oct 28 2007, 03:56 AM) [snapback]531509[/snapback]</div>
    Works fine on my '07. I would try re-entering the code. Maybe it just didn't take for some reason. In any event I find it only mimics the SOC anyway, so I no longer monitor it.
  5. Rest
    Rest Active Member
    1,210
    53
    CA
    I just added SOC and BVT to the SG2 in my 2007 Prius and I also am showing a blank BTV.
  6. burns_fisher
    burns_fisher Burns
    60
    NH
    <div class='quotetop'>QUOTE(Neicy @ Oct 28 2007, 07:33 AM) [snapback]531524[/snapback]</div>
    Ditto. It works fine for me. BTV is not completely like the SOC. It changes more quickly. For example, if you jam on the throttle in reverse (big battery drain) BTV drops (and comes back up when you let up). If you step on the brakes it spikes. I think the measurement is being made in the engine compartment, so you are seeing the voltage drop across the cables. Or perhaps the measurement is made in the trunk but you are seeing internal resistance. In any case, BTV moves around a lot faster than SOC, but I agree that the steady state BTV value mimics the SOC.
    Another odd thing. The lowest digit in BTV flickers constantly. Almost as though there were a loose connection. I suppose the battery voltage is constantly fluctuating, but I'm surprised the SGII/Prius Computer samples it that fast!
    <div class='quotetop'>QUOTE(Rest @ Oct 28 2007, 06:54 PM) [snapback]531699[/snapback]</div>
    Please check EXTREMELY carefully. I messed up a couple times, either putting in the number from the line above in the table, or just skipping a digit. BVT definitely works on the 2007 model.
  7. Rest
    Rest Active Member
    1,210
    53
    CA
    I have checked the numbers three times and they are correct.
    TXD - 0033
    RXF - 0100023B0000
    RXD - 2010
    MTH - 000100010000
    BTV is still not working.
  8. Rest
    Rest Active Member
    1,210
    53
    CA
    I emailed Linear Logic, but have yet to get reply from them about this. I also re-entered the codes for BTV 3 times today, even entered thim in a different memory slot. Still nothing showing up.
    Bill-psi, have you had any luck?
  9. Rest
    Rest Active Member
    1,210
    53
    CA
    My 2007 Prius is an early 07 model. Those of you that got BTV to work in a 2007, was your Prius an early model?
  10. psibill
    55
    Haven't tried anything different, and judging by others' postings, it wouldn't make any difference.
    I guess I'll just have to wait for better intel on the codes, which appear to be model-year specific, and then some!
    --Bill
  11. Neicy
    Neicy Member
    834
    Wakefield, MA.
    <div class='quotetop'>QUOTE(Rest @ Oct 31 2007, 11:27 PM) [snapback]533246[/snapback]</div>
    Mine works on my '07 touring bought in Feb. '07 - that doesn't sound like an early one. I'm beginning to think that maybe some of the units didn't get the complete upgrade before being shipped, since this is a problem with multiple people. I hope Linear Logic addresses this issue soon.
  12. Rest
    Rest Active Member
    1,210
    53
    CA
    I sent my SG2 back to Linear Logic for the firmware update, it's 3.15 so mine should work but it isn't.
  13. bhaynnes
    bhaynnes Member
    225
    Belmont CA
    Mine is a late 2006 and the codes work just fine on them. Not bragging, just more fodder for the fire.
  14. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    Mine is a 2007 and I just installed the ScanGuage II, the codes work.
  15. Rest
    Rest Active Member
    1,210
    53
    CA
    Well this interesting. I finally got a reply from Linear Logic, they say it should work. I don't understand it but I can't help but wonder if when they installed my firmware upgrade it got messed up somehow.
    What other gauges do those of you that got it to work, do you have showing along with the BTV gauge?
  16. bhaynnes
    bhaynnes Member
    225
    Belmont CA
    <div class='quotetop'>QUOTE(Rest @ Nov 1 2007, 02:51 PM) [snapback]533578[/snapback]</div>
    I have RPM, Coolant Temp SOC and BTV.
    I have a late 2006, package 7 I guess since I don't have leather, it has everything else though. The wife specifically asked for "no leather" but loaded.
    Maybe the package you have makes a difference?
  17. Rest
    Rest Active Member
    1,210
    53
    CA
    <div class='quotetop'>QUOTE(bhaynnes @ Nov 2 2007, 09:03 AM) [snapback]533909[/snapback]</div>
    Not sure why it would make a difference, but we have everything except leather seats.
  18. burns_fisher
    burns_fisher Burns
    60
    NH
    <div class='quotetop'>QUOTE(Rest @ Nov 2 2007, 05:51 PM) [snapback]534098[/snapback]</div>
    Exactly what I have and BTV works ok. I also display it with RPM, Temp, and SOC. I got my non-Touring model in August
  19. anti-gas
    anti-gas Reduce, Reuse and Conserve
    56
    South Florida
    I have a 2008 Prius. SOC, BTV, & BTA all work fine. Please note, that the SOC, "State of Charge" cannot be displayed at the same time as either of the others. If you take the SOC off the screen when the BTV & BTA is on there, the SOC works fine. Whichever was on the screen first will work, the others will not. This was given to me by Linear Logic on their data sheet, also posted on the Website. I verified this today in a real world test. Hope this helps you.
