Scangauge Current Drain?
Discussion in 'Gen 2 Prius Audio and Electronics' started by bogeybob513, Jan 26, 2009.
  1. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    I will be storing my 2006 for a couple of weeks and would like to know if my Scangauge will draw any current during that time. The display goes off a couple of minutes after shutdown, but I don't know if it still draws current.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Why not just unplug it and you won't have to worry about a drain?
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    It draws a little current. Just unplug it and you'll be fine. It's pretty easy to start it up again. It remembers the settings (but not the mileage etc.).
  4. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    My scangage turns itself on and off sometimes when the car is parked. The backlight lights up, but no data is diaplayed, since the power to the car is "off". I would unplug it if you don't plan to drive the car for a length of time.
  5. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    Thanks to all. You are correct that the unit is supposed to remember its settings.
  6. srivenkat
    srivenkat Active Member
    596
    93
    IL
    If I leave the SG (ScanGauge) cable plugged into the OBDII port but disconnect the SG unit from the SG cable, will it still result in any additional drain (however small) on the 12V battery when the car is off?
  7. ursle
    ursle Gas miser
    1,049
    192
    NH
