Scangauge II or Toyota dealership
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SamusAran, Aug 31, 2017.
  1. SamusAran
    SamusAran New Member
    Utah
    The red triangle with "problem" appeared on my dash last night along with the check engine light. Usually I take my vehicles into auto zone where they check the DTC for free. Unfortunately, that didn't work this time.
    I can take it into my local Toyota dealership for the standard diagnostic fee, but I've heard users mention the ScanGauge II. Does that device read Prius codes or not? I know it's about $40 more expensive, but I'd rather purchase one and not have to pay the dealership $110 every time the triangle appears.
    Thanks!
  2. Travis Decker
    Travis Decker Active Member
    139
    115
    Portland OR
    Mini VCI off Amazon!
  3. SamusAran
    Utah
    I had no idea something like this existed. Thanks!
  4. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    I have a ScanGauge and it can only read normal OBD codes, the same as the code reader at most local auto parts stores. Best is a Mini-VCI cable with Techstream with a dedicated laptop/hard drive partition. Some other code readers can read the Toyota specific ECU codes, but Techstream can do things like monitor hybrid battery voltages, etc.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Kevin you can send it in with $25 and they will upgrade it to an X Gauge. I did that with my old Scangauge and it now reads hybrid codes, plus there's a lot of pids that can be added too. Many discussions on here about it.
    Search.
    #5 edthefox5, Sep 1, 2017
    Kevin_Denver and Raytheeagle like this.
  6. Kevin_Denver
    581
    422
    Denver, CO
    I did not know that! I still use an old Scanguage from years ago haha
