Scangauge II -- sort of!
Discussion in 'Prius c Audio and Electronics' started by garm, Apr 4, 2013.
  1. garm
    garm mpg + cool = win
    215
    I put in a Scangauge II, but it only wants to work part of the time. (shuts off when the motor stops, decel, etc.) This is a programmable OBDII engine function monitor that I like a lot (for those that aren't familiar with it). It works, and doesn't work, the same way in my wife's '08. I'm going to contact Scangauge to see if there is a solution.
    I guess you only really need it when the motor's running anyway -- LOL.
  2. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    You must set up your gauge to be in "Hybrid" mode. Then it will not cut off when your motor stops.
    Read your book.
    X
  3. garm
    215
    ^ got it. search for "scangauge" didn't turn up the other thread on here (sorry)
    Sleep event > change from 0 rpm
    Gas type > change to hybrid
