Scangauge II VS the Volt
Discussion in 'Chevrolet Volt' started by f16bmathis, Jul 23, 2012.
  1. f16bmathis
    f16bmathis New Member
    50
    New Berlin WI
    Just thought I'd give a heads up to anyone using a Scangauge II on thier Prius. On a 2012 Chevy Volt, it causes the car to die! It also kills the 2012 Chevy Cruse and others. I had a Prius and used the Scangauge every day. Got a Volt plugged in the Scangauge II to reset two codes, and got four more plus a car that wouldn't turn off or go anywhere. The mechanic and I are starting to become good friends...
    49,488
    that's just wrong.:cry:
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    From your description it sounds like your Volt is doing a good job by itself. What are the 6 codes?
    From your experience it doesn't sound like GM or Mr. Goodwrench has changed.
  4. El Dobro
    El Dobro A Member
    6,979
    3,214
    Have you contacted Scanguage?
  5. bajapat
    bajapat Junior Member
    72
    southington ct
    What were the codes
  6. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Very wierd. Clearly a scangage issue.. I use an OBDII device (+ torque) on my Volt almost every day and never had a problem and neither did the many users of DasDaq and about a dozen other volts using generic OBDII devices. Did you use the connector by the driver door or on the passenger side? We know the volt uses 2 different Canbuses.. and OBDII devices should be by the driver.. We also know it uses a lot of the bus bandwidth (about 75% of the time the bus is busy, so if it just locked up the bus or a bit that alone would cause a major problem.
    What vehicle Did you tell your scan gage you were using?
    What were the codes (I have full maintenance manual and can decode them).
    Edit: good discussion (same OP I think) at
    DEAD VOLT II
    Seems to be a scangage issue.. probably not behaving well on the more loaded bus or not following GM's specific protocols. Also may not be able to "reset" non-standard DTC (the EVSE ones are not yet standard), and who knows what it did to the car when it "reset" something it did not understand.
  7. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    Drinnovation, do you have any more PIDS to share? So far I only have battery SOC (thanx to you :), but I wouldn't mind looking at Amps draw.
  8. drinnovation
    2,027
    586
    65
    CO
    Sorry no.. been too busy to do any more hunting.. I've spend dozens of hours looking for those.. now I have a different plan (more automated) but it may be a few months before I get to them.
  9. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    No problem. Thank you anyway!
  10. scottf200
    scottf200 Member
    220
    61
    Chicagoland
    I leave the first generation Scangauge hooked up to my 2011 Volt and have not had any problems. (MPG, voltage, ICE temp, RPMs are only what I can see on this first generation).
  11. Trollbait
    11,560
    I've never had a problem, but comments for those that did only had good reviews of their support. One individual actually was directly contacted by Linear Logic's President or vp.
  12. John H
    John H Senior Member
    2,208
    558
    Did you ever discover any more PIDs for the Volt?
