Scangauge II - X-Gauge
Discussion in 'Gen 2 Prius Accessories & Modifications' started by treehggr, Sep 17, 2007.
  1. treehggr
    treehggr New Member
    230
    So what new gauges would everybody like to be able to program into their newly updated Scangauge II's? I know just about everybody would like to be able to monitor the SOC % but what else are you all looking for?
  2. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Hybrid battery temp
    MG1 temp
    MG2 temp
    Inverter temp
    Hybrid battery current in
    Hybrid battery current out
    Regen brake current
    Wayne
  3. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Wayne,
    I think that you nailed the main hybrid parameters (as long as SOC and Traction battery voltage are there).
    JeffD
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Sorry about my ignorance on the scangauge II but things I wish I could see when driving my Prius are: -
    energy into and out of traction battery
    energy into and out of M1
    energy into and out of M2
    ICE temperature
    HSD temperature
    Inverter temperature
    and the normal MFD display for power flows and instant fuel consumption.
    Something I wish Toyota had included in the MFD is a bar graph of ICE fuel consumption and energy in and out of the electric motors and perhaps the battery. So I can see at a glance where the power is coming from and going to. All this would have fitted in the space of the instant consumption bar graph.
  5. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    <div class='quotetop'>QUOTE(treehggr @ Sep 17 2007, 08:51 AM) [snapback]513623[/snapback]</div>
    I would like to see oil pressure, if that is available.
  6. Doc Willie
    1,717
    144
    Out there, somewhere
    Manifold vacuum. Best instantaneous indicator for how hard the engine is working. High vac = Max efficiency.
    Important enough that I am considering a separate vacuum gauge if I can figure out how to hook it up, and if the installation is not some butt-ugly thing that only a hobbit engineer could love.
  7. brick
    brick Active Member
    1,083
    79
    Upstate NY
    <div class='quotetop'>QUOTE(Doc Willie @ Sep 17 2007, 11:08 AM) [snapback]513693[/snapback]</div>
    Interestingly, the Prius has been shown to do the opposite. Low vac = max efficiency. HSD basically runs the engine at a wide throttle opening and then loads it down to reduce RPM, thus controlling power output. That way it's not wasting so much power to suck air against the closed throttle plate. Most of the time you will see anything from 50-80% load on the SG with the high end of that favored once you get above ~1600-ish RPM. The only time you are likely to see high vacuum (low load) is when the engine is running at its minimum power-making speed of something like 1100-1200RPM and it has to close the throttle to cut power. You will see much higher instantaneous FE numbers but the power also drops off to almost nothing. If you're really lucky the system will give up on the ICE at that point and give you stealth mode. :)
    Low vacuum is good for "normal" cars, but only because that's about the best you can do when the engine is mated to a step-gear transmission. Also, manifold vacuum is already built into the SG so you won't have to mess with the X-gauge feature.
  8. bhaynnes
    bhaynnes Member
    225
    Belmont CA
    <div class='quotetop'>QUOTE(FireEngineer @ Sep 17 2007, 06:56 AM) [snapback]513652[/snapback]</div>
    Oooooh! I like these
  9. FireEngineer
    1,247
    124
    <div class='quotetop'>QUOTE(jdenenberg @ Sep 17 2007, 09:24 AM) [snapback]513666[/snapback]</div>
    Darn, forgot Hybrid battery voltage. Thanks Jeff.
    Wayne
  10. treehggr
    treehggr New Member
    230
    Thanks for the responses. I will be pushing to get these researched and created too. Hopefuly today as I'm anxious to get these all figured out.
  11. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Sorry, I'm easily sidetracked:
    -Battery current
    -Battery temp
    -Inverter temp
    -MG temps
    -Battery SoC
  12. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Hey, prototypes are always butt-ugly! But my panel has no particular
    reason to move beyond prototype stage, because it would have to be
    completely redesigned from the ground up with components still
    available today...
    There's a vacuum fitting on the manifold in the '04+ that used to
    go to the HCAC adsorber blockoff valve actuator in the Classic.
    It's just stopped off with a rubber cap, which you can replace with
    your vacuum hose. Getting it through the firewall is another
    story, but see the imeter page...
    _H*
  13. treehggr
    treehggr New Member
    230
    Just an update. Linear Logic is still in the process of researching all CAN data for the Prius. I'm guessing some x-gauges should be ready within the next few weeks or so. They now have a Prius company vehicle to continue their ongoing research. It's a long wait but should be well worth it.
  14. ivanbg
    ivanbg Junior Member
    Alexandria VA
    Does any one know how the fuel trim can be helpful or what good is it to know it?
