Scangauge II
Discussion in 'Gen 2 Prius Technical Discussion' started by hektorr, Feb 11, 2011.
  1. hektorr
    hektorr New Member
    LONDON
    Anyone know if its possible to change us mpg to uk mpg on scangauge?
    Just bought mine here in UK via telematica from Greece I suppose.
    Thank You.
  2. fuzzy1
    10,163
    Without tracking down the manual, I don't recall if it has a setting for Imperial gallons.
    However, you can calibrate it for Imperial. The easiest way is to simply keep entering Imperial gallons when refueling, and it will auto-cal after a few tanks. For faster results, the manual does tell you how to enter adjustment factors.
  3. Jands
    Jands New Member
    88
    UK
    Hi hektorr, please keep us UK'ers updated with your experience of the scangauge...if everything works on our EU cars etc
  4. cvec7
    cvec7 New Member
    Anchorage, Alaska
    I'm really curious to this as well. I thought I recalled it being one way, but then realized I wasn't sure, and I can't find much hard info on the topic.
