Scangauge Inverter/Transaxle code question
Discussion in 'Generation 1 Prius Discussion' started by depriusoto, Mar 26, 2013.
  1. depriusoto
    depriusoto Member
    113
    17
    Albuquerque, NM
    2002 Prius
    the 02 was driven into a large trailer hitch that was stopping for the light. No one was hurt. No police report. No damage to the big truck. Damage to the Prius. Took a big chunk of the bumper, punched a 5"hole through the upper grille and bent/jammed the hood so it won't open. Looking through the hole the radiator look intact. The aluminum tubes in front of the radiator were bent but I couldn't see any visible breaks or punctures. Car leaked some sort of fluid but it left no stain I was told. Windshield washer fluid? No codes thrown. I went up to where the car is parked and took pictures. Went to my favorite body shop - ball park quote is $3000. About what I expected. Maybe more, maybe less.
    Came back and hooked up the scangauge and started the car up and let it idle. No leaks I could see and no codes thrown.
    Watched the radiator temp and it appeared normal. Monitored the transaxle/inverter temps. Didn't expect to see much unless there was a leak.
    Watching TM1 and it was showing 58 pretty steadily. But every once and a while it would change to D167 or D169 for a second or two and then go back to the 58. My question is what, if anything, does the D167 readout mean?
    In advance, Thanks!
    Ed K
  2. youngnbald
    youngnbald Junior Member
    66
    Bloomington, Illinois
    2001 Prius
    I
    First question I think of: "Do you have the proper ISO cable for the scangauge?"
    I had funky displays before calling the company and telling them I had odd errors. It was a known issue and they sent me a new cable designed for ISO communications free of charge.
  3. depriusoto
    depriusoto Member
    113
    17
    Albuquerque, NM
    2002 Prius
    I'm using the latest scangauge with the Gen 1 cable they supply on request. SO I'm thinking I'm OK on that issue.
  4. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    I would guess that your ac will not work anymore,correct me if im wrong ,but i think the ac condensor is the outer most radiator type of THINGY...They will leak some freon ,but if it has leak detector in it it will usually have a green tint to it..
  5. depriusoto
    depriusoto Member
    113
    17
    Albuquerque, NM
    2002 Prius
    Two of my niece's big friends came and were able to wrench the hood open. The radiator was not hit by the hitch, but a hose is leaking. Is the tubing that runs in front of the radiator for the inverter or the A/C?
  6. bwilson4web
    15,511
    The separate unit is for the inverter/transmission. The A/C condenser is part of the radiator. A clever piece of engineering.
