Scangauge temp question
Discussion in 'Prius c Technical Discussion' started by megaoptimus, Nov 17, 2012.
  1. megaoptimus
    megaoptimus Junior Member
    33
    Missoula, Montana
    Three Touring
    When monitoring the water temperature with a Scangauge; what temp do you guys consider "too high"?
    It's mid 50s right now and I have the grill mostly blocked with pipe insulation. Seeing about 190ish. I'm not concerned, just curious.
    Thank ya
  2. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I saw 202 yesterday on our way home from Memphis. Outside temp was 60. Normal on my gauge is 184-196, without blocking. I am not concerned. It almost immediatly dropped back to 194.
    Dan
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The thermostat is 195F so between 190 and 200 is normal.
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Watch the temp when going up long hills. I saw temps as high as 202F and it stayed between that and 198F until I got over the hill. I had my lower grille fully blocked and temps were 66F outside. I promptly removed some of the grille block. Over 200F is too high for my liking. Neither was the smell of hot plastic.
    RocMills likes this.
  5. fuzzy1
    10,169
    I believe my radiator fan turns on at 202-204F. As long as it hits those temperatures only on brief hills and immediately cycles down, I haven't yet worried about removing the grill block. But when it runs above 195F in steady conditions, then more of the block gets removed. I usually remove just one or two strips at a time.
    If it ever hits 206, the whole block would come out immediately.
    Last year, my block was fully removed for only two weeks in September, when traveling away from cool Puget Sound to an area with 90F+ temperatures. But most readers here live in warmer climates, so shouldn't leave any grill block in place as long as I have. Especially if they lack a ScanGauge or other engine monitor.
  6. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    For what it's worth, down here with no blocking and outside temperatures mostly 18-28°C (64-82°F), I mostly see my coolant temperature at 85 or 90°C (185 or 194°F).
  7. allen2oo3
    allen2oo3 Junior Member
    44
    Orange County, CA
    This is what I have been going off of from ken1784
    Coolant Temp: 200 to 195 quick... | PriusChat
    The thermostat starts to open at 82C(180F) and fully opens at 95C(203F). Therefore, the ICE coolant temperature is ...
    below 180F:blue zone: cold
    180-203F:green zone: good and acceptable
    203-208F:yellow zone: semi-overheat
    above 208F:red zone: overheat
    karabits likes this.
