ScanGauge X-Gauge question…
Discussion in 'Gen 2 Prius Accessories & Modifications' started by WilDavis, Mar 7, 2014.
  1. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Apologies if this is posted in the wrong place (newbie here!). I recently bought a ScanGauge II and have set it up to monitor the charge/discharge of the Traction Battery. I found the X-Gauge parameter information necessary, and I think it's working OK; I use Bta, and my question is am I correct in assuming (oh how I hate using that word!) that +ve readings show current coming out of the battery and -ve readings show the battery being charged? (It sounds counter-intuitive, but careful observation and monitoring when re-gen braking and on the "over-run" (closed throttle) seems to indicate it to be so). Also, any other tips as to what useful X-gauges might be configured, I currently have engine RPM, 12V battery voltage, coolant temperature (I did some grille-blocking, so it's nice to see what's actually happening!), and Bta. Thanks in advance - Wil
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    You are correct on the battery amps that (+) amps are discharge amps from the battery to the MG's. The (-) amps are regen or charge amps form the MG's to the battery. If you think about it "normal" current flow is from the battery to the MG's.
    I typically monitor Bt2 (middle HV battery temp sensor), MPG, ICE Coolant temp, and now with the Boost Converter recall for the Gen 3's I have been monitoring BVB (Voltage after Boost).
    WilDavis likes this.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Did you know you can run multiple Scan Gauges.
    A regular Cat-5 cable works perfect. I made a 10" jumper, run two units side by side!
  4. Jason in OZ
    Jason in OZ Active Member
    271
    112
    Sydney, Australia
    i monitor Bta, Btv, Wtc and Soc on my SGII.
  5. WilDavis
    2,492
    2,153
    49
    Thanks for the info. Yes, I understand about the daisy-chaining; I'm waiting to get some more of the disposable and might invest in a second head. Will the second unit need programming, or does the X-Gauges only require setting-up once?
  6. KK6PD
    4,003
    944
    118
    Each Scan you daisy chain will have to be individually programmed!
  7. WilDavis
    2,492
    2,153
    49
    Thanks, Pat! I sort of expected that to be the answer (if I'd been the developer, I'd have spec-ed it so that the whole system is configurable rather than each separate head! Oh well… (sigh!!) - 73 es tnx - K1WD
  8. KK6PD
    4,003
    944
    118
    It's actually not that bad! You just have to plan and decide what 8 parameters are most important to you.
    I am currently updating the system and replacing the Scan Gauges with a 7" Samsung Galaxy tab! The bonus it has a built in x y inclinometer built it! Torque is really the only program this computer will run. It's strictly a dashboard!
    NortTexSalv04Prius likes this.
