scangauge2/no converter coolant temperature
Discussion in 'Gen 3 Prius Accessories and Modifications' started by StarCaller, Jul 18, 2014.
  1. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    just got my scangauge 2 in the mail today & set it up to show rpm, radiator fluid temperature, converter coolant temperature & amp's/
    now the first two work perfect, the amp I'm not really sure (it shows a "-" sign once the engine is running), the converter coolant shows nothing/
    just for the heck of it I tried the oil temp (it says that it might work or not), but as expected, it didn't work/
    no biggie, that was just playing around a little bit/
    but what's annoying, that the inverter coolant temp doesn't show up; I re-punched all the numbers in: nada/
    neone got ne ideas?
    other than that I'm happy with it, finally I can at least see two of the most basic numbers one needs to know/
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    1) What XGauge configuration are you using for inverter coolant temps ?
    2) The "-" in front of Amps indicates power flow from MG1 or MG2 to the HV Battery, or charging the battery. No
    "-" in front means power flow from the battery to MG2, or discharging the battery.
    3) Oil temp does not work on Prius.
  3. StarCaller
    1,246
    697
    @jdcollins5: that's what I'm using :
    Inverter Coolant Temp: 07E22175 046105750000 4008 00090005FFD8
    is it working for you?
    BION
  4. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Try this one:
    Inverter Coolant Temp: 07E22175 02EA04610575 4008 00090005FFD8
  5. StarCaller
    1,246
    697
    same thing/
    BION
  6. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I checked and I am using the XGauge parameters that you list above. It works fine on my 2010. The second one should have worked also.
    I do not know why it does not work for you. Maybe someone with a 2014 will come along and explain.
  7. StarCaller
    1,246
    697
    odd, because everything else works like it's supposed to /
    BION
  8. jdcollins5
    5,131
    1,338
    Wilmington, NC
    With yours being new I would expect you have the latest firmware rev level. Just curious what is your firmware rev level ?
  9. StarCaller
    1,246
    697
  10. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Yes, you have the latest. So it is not a firmware issue.
  11. StarCaller
    1,246
    697
    ne other ideas or suggestions for changing the parameters?
    BION
  12. jdcollins5
    5,131
    1,338
    Wilmington, NC
    No, I am all out of ideas. The only thing I can think of is a possible change by Toyota in the later models. I was hoping someone with a model similar to yours would comment.
  13. StarCaller
    1,246
    697
    well, I don't want to start a new thread about that, but it would be nice if someone with a '14 model who has the converter coolant display working, would join in here /
    BION
  14. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Call the manufacturer. They have great customer support. Maybe your problem can be solved by getting a CAN cable from them instead of using the generic cable that comes with the gauge.
    #14 xliderider, Jul 20, 2014
  15. StarCaller
    1,246
    697
    I've sent them an email & explained everything/
  16. olieman
    olieman Junior Member
    Netherlands
    @StarCaller: below I have shown the European parameters, they are exact as yours except for MTH is in Centigrade, please test this string of parameters into your scangauge also the parameter ""NAM" tIv t=temp Iv=Inverter.
    if this does the job, change Centigrade to Fahrenheit, change MTH as follows 00090005FFD8
    --------XGauge---------------------TXD----------------RXF-----------RXD------------MTH----------NAM-----Notes
    Inverter Coolant Temp----07E22175-----------02EA04610575----4008---------00010001FFD8---tIv----degC
    #16 olieman, Nov 30, 2014
  17. StarCaller
    1,246
    697
    I'm gonna give it a shot later on & let you know if it works/
    thanks for joining in here with this suggestion!
    BION
  18. StarCaller
    1,246
    697
    nope, still not working /
    BION
  19. olieman
    Netherlands
    What a pity and odd, my scangauge 2 is also version 4.13 like yours.
    I will keep on searching, for a possible solution.
  20. olieman
    Netherlands
    Sorry could not get it posted what I had prepared, I try again later
    #20 olieman, Dec 1, 2014
