SCANGAUGE2
Discussion in 'Gen 2 Prius Technical Discussion' started by DSB, Feb 6, 2007.
  1. DSB
    DSB New Member
    I am considering the purchase of the ScanGauge2 and have looked at many of the "threads" on the site. From those of you that have installed the unit, I have a few questions:
    1) Has it been useful?
    2) Has it met your expectations?
    3) What does it actually measure?
    4) Are their any warranty issues?
    5) Do you have to remove the unit before taking the car for Toyota service?
    6) Is it really as easy to hook up as they say and where is the connector?
    7) Is there a better unit available?
    I have an '06, pkg. 6 and really would like to hear your replies.
    Thanks,
    Don
  2. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    Yes.
    Yes.
    A lot of stuff. Take a look at the website.
    No. There shouldn't be.
    I haven't had mine that long. I probably will just unhook it.
    Yes. The OBDII port is on the underside of the dash about where your right knee is.
    It depends on what you want it to do. There are other options, but I chose this one.
  3. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    I just ordered one yesterday. I considered the Cam View, but what I liked about the Scan Guage was being able to use it on other cars, and the cost. I think I'll get the use out of it playing with it on the prius, and being able to read and clear codes on other cars. It really depends on what you want to use it for.
  4. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Mine is version 1, which functionally is nearly identical to v.2.
    Very.
    Absolutely.
    Skwyre7 has provided the link. You might consider downloading the user manual, available in PDF format. The only listed engine parameters not available in the Prius are MAP (manifold absolute pressure) and FPR (fuel pressure). These are limitations of the car, not the SG.
    No. It doesn't alter the car; it simply displays data available through the OBDII connection.
    No, though it's easy to do. I would remove it if the shop needs to check for codes or work around where it's located. Otherwise I'd leave it in place.
    Answered by Skwyre7.
    Many use Can-View, which integrates into the MFD. It provides more data, but it's more expensive and requires some installation. Between that and having more MFD screens added to those I have to switch between already, I chose the SG. I've also read about CarChip. Like the SG, it plugs into your OBDII connector, but it doesn't give you real time readings. Instead it stores data for later upload to a PC. That would have some appeal to me if I could use it and SG simultaneously, but there is only the one connection on the car.
  5. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    1. Is it useful?
    I bought one and I don't even have my Prius yet! It's saved the cost of the unit already on the anti-Prius (see below), where I got a "service engine soon" light and was able to diagnose and fix the problem myself. The dealer charges $50 just to read the codes!
    You can quickly see why any vehicle is a "gas guzzler" as well. You can even rent first and use it to figure out if you really want to own that vehicle.
    It's the coolest useful thing I've added to a vehicle yet. I use it to learn how to drive with maximum efficiency.
  6. DSB
    DSB New Member
    Thank you all. I was considering the CAN View but the "hook-up" has me scared. The ScanGauge is so simple to install.
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(DSB @ Feb 9 2007, 06:34 AM) [snapback]387370[/snapback]</div>
    I've no doubt you'll get great use out of the SGII, but realize it provides none of the hybrid specific data that CAN-View does...battery SOC, MG and inverter temps, etc. Also, CAN-View's able to show total kW output, amperage out put, etc. Those are all tools I find useful in honing my mpg/hypermiling skills. SGII will get you close and you'll be able to infer a lot that isn't actually displayed, but I wouldn't consider it a CAN-View substitute.
  8. DSB
    DSB New Member
    <div class='quotetop'>QUOTE(efusco @ Feb 9 2007, 07:40 AM) [snapback]387372[/snapback]</div>
    I hear what you are saying and I would certainly have preferred the information integrated into the MFD as CAN-view. Do see enough demand for CAN-view that someone will have worked out a simple electrical installation?
    Thanks for your input.
  9. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(DSB @ Feb 9 2007, 08:10 AM) [snapback]387466[/snapback]</div>
    On the 2005, the installation is fairly simple. On the 2006, if is probably more difficult, but on that I wouldn't know for certain.
    Dave M.
  10. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(David Beale @ Feb 8 2007, 07:43 AM) [snapback]386937[/snapback]</div>
    Not true. Two reasons.
    1. My Rav4EV guzzles NO gas.
    2. This device won't work on the Rav4EV (different OBD2 protocol.)
  11. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    Hi DSB
    The Can-View V4 connects to the OBD II port just the same as the ScanGuage II does. The difference is not the electrical connection. The difference is that you must purchase and install a separate monitor to see the information which the Can-View shows. It is a little more expensive and a little more trouble than the ScanGuage. I have both and I use the Can-View.
    For some ideas about installing the extra monitor look here:
    http://priuschat.com/index.php?showtopic=27906&hl=
  12. DSB
    DSB New Member
    <div class='quotetop'>QUOTE(Allannde @ Feb 9 2007, 01:46 PM) [snapback]387577[/snapback]</div>
    I did not realize that the CAN view connected to the OBDII port. Thank you for that information. I guess I am really interested in a concept that is integrated with the MFD so extra hardware is not required.
  13. dzucc
    dzucc New Member
    35
    <div class='quotetop'>QUOTE(DSB @ Feb 9 2007, 04:28 PM) [snapback]387712[/snapback]</div>
    If you are getting a 2006 or 2007 you WILL need an extra LCD monitor. 2004/2005 you can use the existing MFD.
  14. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    having used both, i can say that scangauge is definitely useful, but i really really really miss the CANVIEW.
    another thing that is not mentioned here, but Norm, the guy who provides CANVIEW is by far, the most pro-active vendor on this site. on my 04, we were getting updates practically every month. he responds immediately to all queries and concerns. that right there is worth a LOT especially on a product that is not backed by a lot of money.
  15. David Beale
    5,963
    1,987
    Edmonton Alberta
    <div class='quotetop'>QUOTE(darelldd @ Feb 9 2007, 09:56 AM) [snapback]387513[/snapback]</div>
    Actually, I beg to differ. Unless your Rav4EV has hyjacked the OBDII codes for distance travelled and fuel being used, the Scangauge II will read 9999 for MPG and 0.0 for fuel consumption (gal/hr) yet would read MPH indicating it's under motion, a pretty clear indication it is -NOT- a "gas guzzler". ;)
    In contrast, even while coasting, the anti-Prius consumes about 1.5 l/hr (more, the faster you are travelling), indicating you can't really expect to improve fuel economy by coasting to stops, gearing down, etc. Which is why I named it the "anti-Prius". :blink:
    How far does that unique vehicle go on a charge, BTW? It's pretty cool!
  16. theorist
    theorist Member
    365
    Lexington, MA
    <div class='quotetop'>QUOTE(DSB @ Feb 6 2007, 10:36 AM) [snapback]386034[/snapback]</div>
    Very. It has allowed me to safely use a winter front (block the grille of the Prius), lowering fuel consumption by around 20% in very cold weather. It has helped me learn driving habits that have helped me lower my fuel consumption by around 10% in my Elantra. I've lent it to friends who've lowered their fuel consumption as well.
    Not quite. I expected it would report a measurement of the amount of fuel being used. It seems that in most cars, it merely estimates the air intake (using intake manifold pressure, TPS, user reported engine displacement, and RPM) and then estimates the fuel needed for a suitable air/fuel mixture. It approximates the fuel consumption better that I could ever hope to, but it's not a direct measurement. If you tell the ScanGauge the engine displacement doubles, it will double the estimated fuel consumption. On some cars the estimated fuel used in a tank differed from the fill-up measurement by 20-30%. The ScanGauge is designed to and recommends that you use measured fillups to calibrate the fuel consumption estimates. I wouldn't use it to quickly compare fuel consumption in different vehicles.
    I was quite disappointed by this but don't regret the purchase. It is still compact, fairly user friendly, and very helpful to me.
    Well it doesn't measure anything but reports data from the OBD II line.
    It only estimates fuel consumed, but the Prius measures and reports that anyways. It does report engine temperature (great for cold weather, safely blocking the grille, protecting the engine, and seeing stage changes), RPM, intake pressure, and estimated gallons per minute and engine load (great for honing the optimal pulse intensity). It also lets me survey how other drive the car by reporting maximum RPM, mph, and engine temperature over that trip, today, and yesterday. It reports much more (everything listed in the documentation except fuel pressure on the Prius), but this is what I've found most useful.
    It would be fun to see Toyota try to show that a problem was caused by reading data using the ScanGauge. Just stay away from using it to send OBD commands.
    Doing so would take less than a minute with a simple installation. I don't. If I was paying for labor by the hour, I might. The techs have found it interesting and enjoyed exploring it; that's fine as long as I'm not paying for that.
    After finding the connector, I can now install it in under a minute while sitting in the drivers seat. Plugging it in and entering the settings might take 5-15 minutes the first time.
    I would prefer the CanView for a 2004-5 Prius. Lower cost, easier installation, a small dedicated display, and the ability to use the ScanGauge in other cars won me over. Now that some user installed GPS navigation systems can display external video, the new CanView is appealing, althought at a much higher cost.
  17. Rest
    Rest Active Member
    1,210
    CA
    <div class='quotetop'>QUOTE(theorist @ Feb 13 2007, 01:16 PM) [snapback]389518[/snapback]</div>
    Not sure where this question came from but, the answer is no. It is no different than connecting a voltmeter to your battery or a timing light. The ScanGauge does not adjust anything, it just reads and displays information.
