scanguage Catalyst temp °C
Discussion in 'Gen 3 Prius Accessories and Modifications' started by edwardob, Oct 14, 2013.
  1. edwardob
    edwardob Member
    227
    33
    ireland
    Catalyst temp C 1 07DF013C 0441853C 2810 00010001FFD8 Ct1 Generic -40 – 6513°C
    i put this into my scanguage....but reading dont make sense
    staring at minus -200 for example but figure goes down as it heats up
    any ideas?
    also what does Generic -40 – 6513°C mean?
  2. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    good question I would like to monitor that temp too, so far I am a beginner
  3. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    Can you share some other samples of numbers you see on your ScanGauge for this? That would help us understand.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    According to Adrian Black's spreadsheet, where this most likely originates, the color denotes that Generic means "Standard OBDII, should work on all cars". The -40 – 6513°C denotes the temperature range of the sensor. So, the -200 that you indicate is outside of the lower range of the sensor so does not sound right.
  5. edwardob
    edwardob Member
    227
    33
    ireland
    yes its an xguage....suppose to be for prius i'll check the numbers again
  6. jdcollins5
    5,131
    1,338
    Wilmington, NC
    It is listed as a XGauge for the Gen 3. I checked your parameters against the spreadsheet and they matched the spreadsheet. From Adrian's comments and notes it appears that this XGauge has been tested and verified. I will have to try it on mine and see what I get.
  7. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    I will try this on my ScanGauge too and see what I get
  8. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I tried this Ct1 XGauge today. The ICE was warm since I had just got home from church. It was displaying 585C.
    I have no idea if this is correct or not but is within sensor range. I will monitor it again tomorrow morning during work commute and see what it does during 26 mile drive.
  9. edwardob
    edwardob Member
    227
    33
    ireland
    i had entered numbers slightly wrong..............doooooooooooooo!
    jdcollins5 likes this.
  10. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Just for info, I have tried both the Sensor 1 Bank 1 (Air Fuel Ratio sensor) temperature Ct1 and the Sensor 2 Bank 1 (Heated Oxygen sensor) temperature Ct2. They both indicated a temperature in the 650-700C range while driving steady state.
  11. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Have you noticed the temperature is 36C too high? If you parked your car overnight, the temperature should be close to ambient before warm-up.
    Here is the list of standard PIDs as defined by SAE J1979. The given formula is ((A*256)+B)/10 - 40. Adrian uses a multiplication factor of 10 so the formula should be:
    (((A*256)+B)/10 - 40) * 10 = ((A*256)+B) - 400 = 00010001FE70
    For me, I did not use 10X since the decimal point is useless for values more than 99.9.
    Column 1
    0 [TH]XGAUGE[/TH][TH]TXD[/TH][TH]RXF[/TH][TH]RXD[/TH][TH]MTH[/TH][TH]NAM[/TH][TH]Notes[/TH]
    1 [TR][TD]Catalyst Temp B1 S1[/TD][TD]07E0013C[/TD][TD]02E80441053C[/TD][TD]2810[/TD][TD]0001000AFFD8[/TD][TD1]Ct1[/TD1][TD]C[/TD][/TR][TR][TD]Catalyst Temp B1 S1[/TD][TD]07E0013C[/TD][TD]02E80441053C[/TD][TD]2810[/TD][TD]00090032FFD8[/TD][TD1]Ct1[/TD1][TD]F[/TD][/TR]
    Vincent
  12. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Hi Vincent,
    I just tried them for the first time today going to and from work. I really did not know what to expect. I will use your parameters tomorrow and pay more attention to ambient temp at startup.
    I also looked for these temps in your ZVW30 Custom PIDs for Android file and did not see them.
    I am going to add these to my Engine Link file.
    Thanks,
    Dwight
  13. bwilson4web
    15,518
    Minor detail but I noticed with the miniVCI, the catalytic converter temperatures show as the 'last running' value. Once the engine starts, they drop down to ambient. A small effect with about a 10 second duration, still it surprised me.
    NortTexSalv04Prius likes this.
  14. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Bob,
    I noticed that too last night and again this morning. I was hoping to get a true ambient reading but as you say the value displayed at Ready is the last value at shutdown. Once the ICE starts and the value updates it is already climbing with ICE running. It is hard to get true ambient temp but close.
    Dwight
  15. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Vincent,
    I tried your parameters and they were in the 36C range lower than Adrian's. The starting temp was close to ambient but as Bob said it does not update until the ICE fires off so hard to tell.
    Thanks for your SAE J1979 formula above. I was able to use this formula in the Engine Link PID and this worked fine.
    Dwight
  16. vincent1449p
    894
    331
    Singapore
    Torque already has it in the std list, however, I did post a mode 21 in the PiP section.
    I 've observed the same in my c. Now I understand why the PiP is showing 761 deg F in EV mode (without ICE firing up).
    Vincent
  17. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Catalyst Temp B1 S1, CAT B1S1, 2105, (E * 256 + F) * 9 / 50 - 40, -40 11756.3, F 7E0​
    Catalyst Temp B1 S2, CAT B1S2, 2105, (G * 256 + H) * 9 / 50 - 40, -40 11756.3, F 7E0
    Vincent,​
    I tried your PID's from the PiP section that you linked above. The B1S1 responded but the B1S2 only indicated -40. I was sitting in the driveway so did not run the engine long once I saw the B1S2 not responding. See below for the obddata.log file response:
    >2105
    7E8 10 08 61 05 4E BB 08 F5
    7E8 21 04 CB 00 00 00 00 00
    There are A, B, C, D, E and F values but the G and H values are zero.
    Dwight
  18. vincent1449p
    894
    331
    Singapore
    >2105
    The response shows 8 bytes, which means G and H are not included. PiP has 10 bytes so it is different from Gen3. You can try to compare against the mode 1 response:
    Catalyst Temp B1 S1, CAT B1S1, 2105, (C * 256 + D) * 9 / 50 - 40, -40 11756.3, F 7E0​
    Catalyst Temp B1 S2, CAT B1S2, 2105, (E * 256 + F) * 9 / 50 - 40, -40 11756.3, F 7E0​
    Vincent​
  19. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    That's what I get with my Ultragauge.
  20. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Vincent,
    The above settings exactly match the Mode and PID 013C and 013E values from the standard list. So you can add these to your ZVW30 spreadsheet if you would like.
    I looked at the Engine Link Standard List and the 013C and 013E values are listed.
    Thanks again,
    Dwight
