Scanguage reset and codes
Discussion in 'Gen 2 Prius Technical Discussion' started by AF1PRIUS, Oct 30, 2008.
  1. AF1PRIUS
    AF1PRIUS New Member
    35
    Southern, MD
    This morning after filling up my car and then looking at the scanguage's fuel tank data, I decided to reset it and start over. When I did, all **** broke loose:eek:. I got a check engine light and a red triangle. Also the following two codes can up: U0100 and P0000.
    I tried to see what they stood for, but no luck. The scanguage did reset. Not knowing what I should do next, I decided to clear the codes and see if that turned off all the warning lights and it did. The car started and appears normal again. Will not really know until I leave work for home.
    Any thoughts?
    AF1PRIUS
  2. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    Sure sounds like the Scangauge put something on the CAN bus that the car did not like. I've sometimes wondered how much of a hazard of that sort of thing there might be--especially if one has XGauges for another model of car loaded.
    Which exact reset did you issue?
  3. AF1PRIUS
    AF1PRIUS New Member
    35
    Southern, MD
    After I scanned for the codes, I just cleared them and all warning lights went out. I started the car (turn the power on) and the engine started and no more warning lights lights came back on so, I am hoping that when I drive home after work, all will be well.
